161 - 178 of 178 Posts
A bigger turbo is going to increase your cruising egt's...
No it wont. I went from a hybrid to a 68mm vgt. Cruising temps stayed the same. Even when I went from a 64mm non vgt to the hybrid then to the 68mm vgt...cruising temps at 65-70mph were exactly the same.
How do you like the stage 3? your running 190/100's correct? What are egt's on WOT runs?
Not many miles on this turbo yet....less than 100 before I drove it to Warren Diesel to have some work done. So maybe 200 miles. Tuning needs adjusted big time. Tried TSD's SPD and shift points need fixing big time. Running 190/75's.
Ok today I was able to hook up my 5th.Currently I have Matts unlimited tow loaded,my 5th weighs 12800 dry.I have some pretty good hills here,but basically at 65 once I got leveled out my egts were around 800-850,now of course going up hill they went up,but not real bad maybe 950 depending upon the run before heading up the hill.Truck seems to have more power ,now again this is Matts unlimited( I do have the php atlas 40 ficm tune)which I think adds no power,just trans only adjustments.I will be taking a longer trip in 2 weeks,but the egts seem to be the same as the stock injectors or pretty close as I remember .I am hoping for lower egts once I get the new turbo,but so far, they seem to be in control.
How was the shifting... did Matt hit shift points first try? He kind of bombed with the shifting on my tunes as did Chris... files from both tuners shifted almost identically. . Way early. . Chris was easier to convince to move shift points.. I will work on Matt soon... lol
I did forget to address that,yes way to early,was more concerned with watching Egts.All of my tunes from Matt shift to early.I have been working with him too.I need to see about getting this tune adjusted too.
Crazy... you contact these tuners and they act like you are the only one that needs shifting tweaked.. get Matts dialed for me and I'll continue to work with Chris'. I have a modded mpd to pull my 5th, in my in box right now!!
While my truck is down at Warren's I'm gonna have Jesse write a street tune for it.
I was told to get them to write me a tune.I actually emailed Jesse to see about getting one.
I
That's seems pretty good, not ideally what I'd like to see, but for your setup and that weight I think your doing better than most
Sent from AutoGuide.com App
I
I still think the tow tune could be better.Even with stock injectors there were rpms where the gets are not good,like 55 to 60,but that's not where it likes to run anyway.The other thing is once I get the other turbo,I will still need adjustments.Since I have a ported WPE intake I am sure that helps too.i am still looking at other ideas maybe getting and intercooler down the road.
Could I suggest that you start your own build/progess thread.. I am very interested in your build and the fact you are not the original poster for this thread..
Reactions: windrunner408
Yea Robert I agree with Aaron, start a thread man. You've actually done A LOT to your 6.0. WAY more than the average guy has and you tow quite a bit too. Besides man, we're trying to push your truck to absolute limit for power and reliable towing duties.
Ok ,I will start a new thread.
Reactions: william_ace
Just to clarify a few things... not that it matters much.
The MTW stage 2 is not offered anymore and was a great turbo. I will explain the differences between the barder and mtw just for clarification
Mtw stage 2
.72ar comp cover
64.7x88 comp
72x66 turbine 13 blade
Barder stage 2
.58 comp cover
64.7x88 comp wheel
72x66 10 blade turbine wheel
The mtw stage 2 is not offered anymore because the desirable .72ar comp covers were hard to come by and got very expensive
on the MTW site they have the stage 2 but i guess like you said its not offered with the .78 but with a .58 comp cover. is the current stage 2 a good match for a set of 190/30?
ive read other post that a guy was able to get just over 500 rwhp with just tuning on stock sticks on this turbo.
I would say stage 2 is to small, a 68/stage 3 is what you would want. IMO
Most people who are big into towing don't go with 190s. That is just too much fuel and it will be smokey, or you will have to pull a ton of fuel to even make it possible to tow something that heavy. 190s will haul butt!!! But not a lot of weight, unless you can clean them up with a larger turbo charger and more air flow. Although to a certain extent once you get so big on the turbocharger you will have more lag and it will be easier to get under the turbo and it will make towing and egts even worse.
Also what do you have done to the truck so far?
Head studs?
Bulletproff?
Any updates?
Oil cooler?
EGR?
Tranny?
Maybe I can ask this question. Why 190s? Is it for racing and/or dyno... or are you under the impression that it will tow more?
I don't have a tow queen but I heavy followed many people on this forum and bigger is not always better unless you have LOTS OF MONEY!!!
155/30 and a stage 1 turbo has proven to be a great tow combo. You can actually floor it up hill on a good tune. With 190s you will have to be constantly watching your egts, pulling fuel from the tune, and with a big turbo that can actually clean up your 190s you will lug the motor and fall under the turbo and also have much more turbo lag. No reason to get a giant injector that will just have a ton of fuel pulled on it... Unless you are looking for a major dual purpose truck??? Or if you have a ton of money!
IMO 190/30s, compound turbos, head studded and complete bullet proof, ported intake, ported heads, aftermarket air intake, complete fuel system, regulated return, water/meth injection, a fresh hpop (needs to be in good condition), a built tranny etc.. etc.. This would be one mean towing machine
Or you could just do 155/30 and a stage 1 and have almost the same towing ability :)rofl:like 60mph uphill instead of 90 mph uphill 🤣)
exactly :thumb:
What this guy said
So I came across an old thread and your comment and I wanted to see if you could chime in. I have a stage 1 fully built motor bored 20 over with coated fly cut pistons stage 1 cam, Odawg ported intake, banks techi cooler and high ram intake/intercooler system, a stage 2 momentum intake, full arp everything, fast fuel pump regulated fuel return, oring heads, stage 3 water meth injection. New hpop, bd exhaust manifolds and up pipes 4 in down pipe to 5 inch straight exhaust and A turbo time USA gxr11 predator velocity port turbo and a stage 3 ats transmission. Do you think it would be foolish to run 190/30 injectors on my setup in Florida?? I do highway towing. I plan on having several tunes for different weights as heavy would be Gcvw of 45,000lbs and regular would be GCVW of 24,000lbs and empty 9,000 lbs truck that cost me tons to build so besides having the best tow rig I wanna be able to Dyno good and have fun driving empty with out loosing capacity??
Warren 190/30s with stage 2 motor being built. New BW 366 turbo, banks upgraded intercooler and pipes, upgaded fuel system w regulated return, built heads, ported odawgs intake, built tranny, and I won't be towing heavy (often) with that setup. too hot and too smokey. But we'll see.
It should pull great mpgs unloaded. Expecting 22-25 highway and will haul ***. I'm thinking the new turbo will help a lot.
Old motor ran a smeding 363 non vgt turbo with the same 190/30 injectors, factory intercooler, custom tunes, was great for sporty driving but it would get hot and didn't clean up well at all. Very smokey. I got pulled over for smoke in NC when I wasn't even on it hard, just made a right on red in traffic and had to get moving. This setup got great economy, 26hwy, 20-22 mixed and was pretty quick.
