And yet, in post #7, Ford's second procedure, TSB 09-8-3, modified to a lower than 25ÂşF maximum.
It does exist on this site.
COOLANT LOSS—6.0L TSB 09-8-3 - Powerstroke.orghttps://www.powerstroke.org › attachments › 09-8-3...
5. Road Test For Restricted Oil Cooler - Setup and Observations:
a. Install integrated diagnostic system (IDS), select engine coolant temperature (ECT) and engine oil temperature (EOT) PID's on IDS Datalogger.
b. Carefully drive the vehicle at wide open throttle (WOT) / high load to achieve maximum boost.
NOTE: FOR ACCURATE TEST RESULTS, ECT TEMPERATURE MUST BE GREATER THAN 190°F (88°C) WHEN MEASURING THE ECT AND EOT MAXIMUM TEMPERATURE DIFFERENTIAL.
NOTE: PERFORMING THIS TEST STEP OUT OF SEQUENCE CAN RESULT IN INACCURATE TEST RESULTS. THIS CAN BE CAUSED BY A LEAKING EGR COOLER ALLOWING (HOT) COMBUSTION GASES TO ENTER THE ENGINE COOLANT AND ARTIFICIALLY RAISING ECT READINGS.
c. Observe ECT and EOT PID's on IDS Datalogger. EOT maximum temperature differential might occur at throttle tip-out.
1. If EOT is within 15 °F (8.4 °C) degrees of the ECT, go to Step 7.
2. If EOT exceeds ECT by 15 °F (8.4 °C) or more at any time during the test, go to Step 6.
