05 f350 6.0 injector 4 contribution/balance failure
9.2K views 40 replies 5 participants last post by  bismic
Getting the code P0272 injector 4 contribution/balance failure. There is a new injector wire harness put on, new fuel pump because of blowing bubbles in the upper fuel filter. The truck starts but wont idle for more then a few minutes.
I have AE and i put the idle set higher to 750 and it will stay idling and u can feel a miss in the motor every once in a while and only last for about a min or 2, so when it had the miss i turned off injector 4 no change in motor behavior and so i enable it wait a few min and it would clear up then start missing again on its own i would try to turn off 1,2,3,5,6,7,8 while it was running rough and the motor would get even more rough. the only one that i would turn off and not make a difference would be 4. Could this possibly be a bad injector?
All parameters of motor all good, ICP, FICM, IPR, Oil pressure. Volts.
#2 ·
With 1 injector out and it being cold, it may not idle properly, but usually would not stall. In any case, you have correctly identified the problem. Whether it is electrical or the injector itself is another matter. What happened on the buzz test; that may help in your decision going forward.
Pull it and have a good look it, including the nozzle. You could try moving it, but if the electrical signals are good, you are wasting time. Best option is to just replace it with a new style injector, and then, perhaps play with it (take it apart) following the process in my sig.
#3 ·
Getting bubbles while cranking?
#7 ·
Just brought it for a drive. During the test drive it only made 10 PSI of boost. No power when WOT. All parameters good, when i disabled injector 4 no difference in the motor while driving. I delete codes on the road and injector 4 contribution never came back on but still stalling at idle.
#9 ·
Im second guessing it. Could it be a bad FICM although i have 49 volts? When i set the idle to 1000 rpm the truck is running fine but again no power, 10 PSI boost and at idle it is dieing. I also have a code for camshaft position output circuit/open but my Cam shaft and crank is SYNC and FICM is SYNC.
#12 ·
It might or it might not. Since you really didn't answer my question, I will answer it. Your test of disconnecting #4 injector shows that it is not contributing anything now. That is a problem and it needs to be corrected - even if it isn't the only thing that is wrong.
You could test the wiring to that injector with a meter (not a bad idea), but you "sort of" did that test with the buzz test. You don't have a way to test the FICM unless you have a known good one to install and try. And typically one bad injector is not the FICM. Best of luck!
#14 ·
Swap that injector to a different hole -- if the problem follows, then you have the answer
#4 is currently not working, so that is a problem -- need to figure if it is the injector or the ficm or wiring
the buzz test if you hear all the injectors, should rule out the ficm - and electrical part of the injector
#15 ·
Alright, thats kind of what i was thinking todo but wanted to check out a second opinion before i pull everything out again and sink more money and time into it if it could be something else and it was just triggering an injector code. Buzz test successful. New wire harness. Problem is only intermittent and will not idle for more then a few seconds. I figured a bad injector would only cause rough idle but would stay running. RPM surges about 30RPM staying around 680 to 720 for the time it stays running. When idle it up to 1000 it will also surge around 30 rpm. When could the truck will idle for a few min then thats it. HPO is over 600 at all times.
#16 ·
May also be a leaking copper washer, letting compression into the fuel rail
that will usually affect the whole bank, but starts at one injector and spreads to the others
#21 ·
What does the IPR percentage and ICP sensor voltage (not pressure) do when the engine starts to die ?
Reactions: bismic
#23 ·
OK, good -- you dont have an oil pressure problem there , or the IPR value would go up at the end
You aren't getting codes for the pedal sensor ?
Does the engine just slow down to a stop? -- or just quit firing altogether ? like the key was turned off
Have you watched the load pid to see if it spikes ? -- not real sure how load is calculated
#24 ·
No codes for pedal sensor. The engine shuts off as if i turned the key off. Its as if once the truck is at operating temp and its not giving it enough fuel to stay running but when its cold starts and runs fine for about 5 min. No nasty smoke only a white puff when it is initially started. I just put a brand new fuel pump in and sinister blue spring kit.
#27 ·
Since the engine just cuts off -- we are prolly looking at an electrical problem
if it were fuel, there would be some sputtering just before it died
#29 ·
#30 ·
Without a code popping -- the system "thinks" it is operating normally
so have to look at things that do not produce a code
but yet, just cuts the engine off
no sputtering at all ?
RPM act goofy before it dies ?
#32 ·
What is the alternator and battery voltage at the low idle after 5 minutes? The part that is puzzling is the 5 minutes and it keeps running at a higher idle.If the voltage were to drop to 9v, it would quit running. If the HPO sensor dropped below .8v, it would quit. If the fuel pressure was very low, it would quit. If you lost Sync (Cam or crank) it would quit.
The key to the issue is to know what parameter is lost when it dies. Until that is known, we are just chasing ghosts.
#33 ·
