This is how the ESOF works
13K views 7 replies 6 participants last post by  NYC F-350
I have read lots of threads asking how it works and how to test and how to operate. Well here it is.
View attachment ESOF.pdf
#2 ·
Thanks.. Another good PDF to have for this trk.
#3 ·
Great post! Thanks, bud!
#4 ·
Very nice! Thank you.
#6 ·
If you need more just let me know.
#7 ·
my driver side hub is really hard to turn by hand and it doesn't engage when i use the ESOF (passenger side works fine). i've been turning it manually with pliers but i'm wondering if it just needs to be greased or something.
anyone have the same problem? i wish i could replace them with aftermarket like the 99-04 style...
#8 ·
my driver side hub is really hard to turn by hand and it doesn't engage when i use the ESOF (passenger side works fine). i've been turning it manually with pliers but i'm wondering if it just needs to be greased or something. anyone have the same problem?
The passenger side hub on my truck was hard to turn by hand last winter. It wasn't as bad as having to use pliers but it gave your forearm a good workout to get it to lock. After the snow finally melted, it slipped my mind. Then the u-joint on the axle shaft went. When I removed the hub, what I saw inside wasn't pretty. A few needle bearings and a bunch of metallic slivers inside the wheel bearing where the hub sits. I cleaned that out, looked at my now dead hub, greased the heck out of it and stuck it back together. It turns easily now (that it is dead) and does engage the axle (probably only until I need it, then it won't lock). I just don't know how reliable that will be.
My advice is to take out the three torx head screws, remove that hub and clean inside the wheel bearing and the hub. Then grease the hub much like the old style 2 wheel drive wheel bearing and stick it back together.
You can, but it requires about 2 grand in parts. Dynatrac Hub Conversion Kit
