should i use loctite?
1 reading
6.1K views 4 replies 4 participants last post by  wakeupluis
i need to know if i should use loctite on any of my bolts when i rebuild my 05 6.0, and if so what color grade i should use?
#3 ·
#4 ·
The problem here is that if you use LocTite on the bolts that you are going to take off again in some months, let's say Oil Cooler, HPOP and such, you are going to have a bad time.
You should only use the torques that the manual has, and it has toques for all of the bolts on the engine.
