My 2006 has the steel cover, going to change the fluid and thinking of using the newer style aluminum cover. What year did they convert over? I have the Superduty 6.0 diesel 3/4 ton 4x4. Also what is the recommended fluid?
Here is the relevant page from my 2005 owners manual. Looks like you need to figure out which rear end you have.Also what is the recommended fluid?
I think there is some cooling benefit, but most of that benefit is necessary when you get into the newer truck's higher weight capability. Is it worth it - maybe not.
The only benefit is its easier to service and looks nicer.There is a reason that a lot of dually's come with finned aluminum covers. Yes it does help. Having more fluid capacity also helps. Personally I like the covers with drain and fill plugs. Easier to service.
Ford generally has had a great reputation regarding their axles. Dodge, not so much. Dodge axles were notorious for failures. Separately, there was also a big focus a while back on the heat treating of parts leading to failure. Heat causes expansion, and widening the range of expansion will have its affects. Some manufacturers have their processes dialed in better than others. Would I be concerned enough to worry about it on a ford? No. Does cooling provide a benefit to axle bearing or seal longevity? Not enough data, but ford will sell you one.How many rear differentials fail? My gut says, not many.
How exactly does it help to have a larger volume cover? I don't particularly want to hear about lower temperatures, because that may not really help anything that matters, ie differential longevity! It is not the same as engine lubrication!
I have really only encountered one failed differential (not mine). Also, I have seen almost none discussed on the forums, although I certainly may have missed many of the discussions on it because I do not frequently peruse the general SuperDuty section.
