Avoid additives that include alcohol
Seafoam has alcohol (IPA - no it's not beer in this case - isopropanol) in it too which is not a desirable additive for your fuel.
MSDS - MSDS
As alcohol attracts water and combines with it, water is unintentionally allowed to pass the fuel-water separator. Water in your combustion chamber is converted to steam when the alcohol vaporizes. Steam builds ENORMOUS pressure...notably beyond the TTY bolts' capacity...headgaskets fail or heads buckle - neither is desirable.
Alcohol also increases the so called scar-test metal wear on a high frequency reciprocating rig (HFRR). I've attached a test of various fuel additives from several years ago. The test is a thread here too. There are plenty of alternatives without alcohol to perform the desired fuel system maintenance.
With all of the frustration of gas engine enthusiasts at federal requirements to utilize E85 I think it would be odd to want to put alcohol in the fuel tank especially without fully understanding the consequences. Certainly there are those who use alcohol based systems for cooling combustion (water-methanol) and gaining power but those are deliberate choices hopefully made while fully informed of how water contributes to compression (pressure) increases.
In closing, water reduces the capacity of ULSD fuel to lubricate (generally undesirable), lowers combustion chamber temperature (generally desirable), but also increases combustion chamber pressures (potentially desirable if adequate reserve clamping torque for the heads is in place - not the case if not running ARP/H1 studs...i.e, not a good idea for TTY bolts).
Try an alternative to SeaFoam if you can't accept the limitations of alcohol infused treatments.
Hope this is informative for those who didn't know and not taken the wrong way by those who understand their selection.
Jonathan
