I'm starting a new thread hoping for an answer to my issue because I doubt anyone wants to read my really long thread to how I got to this point. How do I connect 3/8" ID rubber fuel injection hose to the steel inlet on the HCFM? The 3/8" hose I bought (also marked 9.5mm) is a sloppy fit on the steel so it must be bigger than 3/8" because the steel is right at .375". If I could get it over the "barb" then it might be okay because I could put a clamp on the other side of it. Can I buy fittings that have the quick connect fitting on one side and a 3/8" hose barb on the other end? The Dorman ones I found are mostly used for GM fitting with 5/16" nylon tubing on the barbed end according to reviews of them. How would you guys connect these things together?
Here is my long thread on where it all started.
No Power, Bucking, Stalls, P0282, P0279
