Bench seat to bucket seats
1 reading
15K views 16 replies 9 participants last post by  036speed
My bench seat is torn up and extremely sunken down after 305k. I want to put the bucket seats from another obs with the center console seat in my truck. I want to know if they will bolt up exactly to where the bench seats were. If anyone has done this let me know. Thanks,
Mike
#2 ·
i had the factory solid bench in mine not the 40/20/40 split and switched to bronco seats and center counsil all i could do is use the front bolt on both sides from the bench and had to drill the other 3 holes per seat and used a crush nut under the body and it worked out pretty good
#3 ·
What you are describing is the 40-20-40. They came in 94-97 trucks
The seat frames are cab specific
Regular cab and crewcab, use the same seat pan.
Supercabs use a different one.
Broncos use a different one again(they never came with a 40-20-40 anyway)
#4 ·
late 80's had the 40/20/40 too and will bolt, and what cab do you have
#6 ·
Upgrade to a set of SD seats... Ditch the factory seat pan, with slight mod to SD seat brackets they will bot right up...
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone...
#7 ·
^^^ Can we see some pics of ure SD seats in ure rig... i really want to do this with 08 seats someday.
#8 ·
I will post them up as soon as I am back infront of my computer again...
#9 ·
I had to drill all new holes to install sd seats, and beat the tabs a bit up front to go down the slope of in front of the drivers seat, the rear I just bolted to a modified factory seat pan, removed marked holes filled the old ones with silicone, put the carpet back in and drilled the carpet and bolted all the seats down, took a while to get it all aligned up, if you go sd than be sure to have a free weekend and some help, but so worth it, as soon as I get my computer back from the shop I can post piks too
#11 ·
You never see regular cabs with bucket seats. My crew cabs bench seats are way to comfortable to even think about getting rid of them and I love bucket seats.
#14 ·
I pulled mine out of an 89 crew cab. There were two rows of 40/20/40s in the cab. They were not at all the same ones that came in the 94+ models, but they were 40/20/40s. Now do I know if they were FORD factory seats? No. They could have been from an aftermarket or custom builder like Centurion. But they were designed specifically for the F-series cab floor. They bolted perfectly up to the seat bolts in my '90 reg cab.
Not arguing, just saying I've seen 40/20/40s in late 80's F-series trucks. :ford:
