I think mine is starting to leak, not overheating, just have a small leak from somewhere. Any tips on how to check the water pump ? I know it has a weep hole, kinda hard to see
Thanks, Jim
Thanks, Jim
Only way to find it is to remove the pulley and look under it with a mirror. If it isn't coming from the manifold donut or other local source it is probably your water pump. Once you're in that far and it is an older pump, might as well replace it.I think mine is starting to leak, not overheating, just have a small leak from somewhere. Any tips on how to check the water pump ? I know it has a weep hole, kinda hard to see
Thanks, Jim
