I have a 2004 F250, 6.0L, I pulled the turbo to replace a leaking EGR hose. Once it reassemble everything I fired it up and had noticeable air leak. I checked all the obvious areas, hoses, clamps, ect. If I remove the small wire going to the VGT Solenoid it stops. When I plug it back in, its starts blowing out the blow off or the back side of the VGT. I pulled the VGT, looks good, and it worked fine before I pulled the turbo. Could it be a bad solenoid on the VGT?
Chris
Chris
