Yes, they are all within about .3 psi of each other. Truck seems to have plenty of power. Idle boost is zero when cold. Cruising boost runs about 6 to 10 psi no load up to about 28 psi WOT. Until the VGT % gets off of 85%, the EBP stays at about 14.5 psi which is close to the MAP reading. Once it goes below 85%, then the EBP starts changing.
Bismic, I have watched the video. I guess I need to watch again. I have read and looked at so much in the last few months I have forgotten a lot of what was seen.
ChrisSki, I will check that again. He did an EGR delete at the same time, so there will be time charged to that also. If I remember correctly he had a total of about 5 hours charged. The other stuff I listed was what I have done to it.
One reason I have lost confidence in this mechanic is that I read off some of the possibilities to him, like the MAP sensor line, and he said that was the first he had heard of that. Same with the intercooler boots.
I guess what is confusing to me is that pretty well the only time the code is thrown is either at idle or right after I start moving and have not even hit the throttle. Expected EBP when I use the SCT to monitor is around 17 psi, but actual is usually around 14.5 at idle. The Scan Gauge doesn't give expected EBP and that monitor is what is usually hooked up.
Could it be that the vanes are sticking open at whatever percent they are on when I stop the engine and never fully closing at startup? Is it possible they could stick only at low RPM and work fine at higher RPM?
Sorry for all the questions. I am trying to learn about this truck, like it, and want to keep it.
