Using Tow/Haul Mode vs Manual Shifting in a 2012 6.7L Powerstroke Ford Truck
4.8K views 11 replies 8 participants last post by  Kaakau620
#1 · (Edited)
Hai,
Is there any significant difference between using the Tow/Haul mode and manually shifting a 2012 6.7L Powerstroke engine in a Ford truck? Does the Tow/Haul button offer any advantages or changes that cannot be achieved by simply manually shifting the gears? I'm curious to know if using the Tow/Haul mode provides any additional benefits or if manually shifting is sufficient. Give me your recommendations.
Thank you!
Access NJMC Direct search for tickets by license plate NJ, and purchase tickets online nj en españo by the New Jersey Motor Vehicle Commission all are available in en español with easy login options
#2 ·
When I’m towing my fiver, I like to keep it in tow/haul for the engine braking via downshifting. If I need to hit the brakes and stop in a hurry, I can focus on the situation as opposed to trying to find that small shift button.
Otherwise, there’s no other real advantages. The owners manual actually suggests turning it off on flat ground when at cruise speed to increase fuel mileage.
#6 ·
Using the toe/haul increases the rpm shift points. The higher shift point has more fuel going through it so you get more soot in the exhaust. More soot means more DEF to burn it out.
On flat land I will not use the tow mode when I have an empty gooseneck. It gets better fuel mileage. Any load or hills I will have it in tow mode.
#8 ·
The biggest difference between manual mode and tow/haul, is your torque converter lockup schedule. For example- stock tow/haul will not go full lock in 1st gear, manual mode it goes full lock over 7mph. Same thing with tow/haul vs normal. This is the other major factor besides rpm, that effects fuel mileage/def. TCC lockup increases load, which increases fuel demand, which increases soot, which increases def usage (if stock).
