Just set these codes today. Of course now my glow plugs are not working. Truck has H&S high sulfur tuning. Put i8n a call to H&S but they were 0 help. Told me to call ford. Anyway anyone else ever see these codes pop up and get it figured out?
I had a 2011 duramax that I left the plugs hanging uncovered and never had an issue. I know it's a duramax but just piece of mind. Also, within about a year, the salt will eat the prongs right out of the plugs. Learned that the hard way.Not sure if anyone has solved this issue yet? I have a 2016 fully deleted Superduty. Using SCT Livewire TS+ with 5 tunes from Tyrant and 4 from No Limit. I am experiencing the same issue. I replaced the fuse and it blew again immediately. I crawled under the truck after reading this post and after putting another fuse in the #36 slot. It blew it again of course.
Here is what I found.
1. Strong burning electronic smell from the sensor controller part# dc3a-5k202-ac under the passenger door on the outside of the frame rail.
2. Burnt terminal inside the terminal housing. This is one you unplug when deleting the DEF/factory exhaust.
3. The female end of the plug faces up into the air like a "cup" to hold water/debris.
4. Lots of salt inside the plug.
5. My remote start no longer works.
6. I have a code U0106 - Lost communication with glow plug module 1.
So my experience in electrical engineering and salt spray automotive testing has taught me salt is highly conductive. I think the power is left on after deleting and is creating a carbon/salt bridge between terminals causing the sensor controller to short and blow the #36 fuse.
I'm calling to get a replacement now, so I can't tell you if swapping it out and sealing off the plug helps until it arrives. Also replacing the fuse of course.
Interesting. So it sounds like there is about a million things that can cause those issue. I’m baffled that this throws off the glow plugs. None of these issues seem to have any relation to them.Just wanted to update the thread. Switched out the sensor control module. Everything works fine. Control module was shorted from salt and water. I would love to post attachments to show you but this forums rules are stupid.
Edit: By the way you NEED this sensor. Especially if you have remote start and want to use your glow plugs. You CANNOT just unplug it!
