OK..so I am new to this forum and I hope I can get some advice and also pass on some recent learnings. I was headed across rural Ga in my 2004 Excursion when tow/haul light starts flashing and truck goes into limp mode. This is not too alarming as I have already experienced the dreaded temperature gauge issue and survived so I am not too worried (should have been but wasn't). Decide to stop at my local Walmart to check it out and when I shut down the truck it will not crank...I don't mean it wont start I mean that the starter will not activate. Long story short I am able to jump the starter circuit and get it home. Now after looking at wiring diagram am pretty sure this is related to the Transmission Position Sensor (aka Neutral Safety Switch). Not only does the truck not crank but it also shows no reverse lights so this sensor is not getting any power.
But in their infinite wisdom Ford now located this sensor inside the transmission. I have dropped the pan and taken a look but this seems quite complicated to remove and I can not find any videos or advice on how to remove.
So 2 questions. 1) Anyone know how to remove this and successfully reinstall? (There is a note printed on the mounting bracket telling one to not bolts as it requires recalibration). And 2) If there is something in the wiring other than the Neutral Safety Switch that could be causing this?
Thanks for any help you can send my way. I am hopeful that this is not one of those $30 parts that cost $500 to replace.
