sudden loss of oil pressure and engine died
1 reading
17K views 14 replies 4 participants last post by  SCUFFY828
Just had a problem with my truck today and though I would see if anyone had seen it before. sudden loss of oil pressure and truck died. was just sitting at a stop light and one shudder and check gauges light. then died and would not restart.
Joe
#5 ·
he said the check gauges light came on, so my question is if he lost base pressure then yes it would shut off cause it couldnt feed the reservoir ,not likely with a 6.0 but i have seen trash in the regulator cause a no start or shut off concern , and in your situation with the ipr problem after a oil cooler repair i have seen that a few times myself
#6 ·
Yes it matters. You won't get high pressure if you don't have base. If you crank the truck for a bit you should be able to get pressure on the gauge. If you can't get pressure on the gauge (base oil) then you're looking at oil pump, pickup tube or some other internal engine issue.
#14 ·
the oill gauge was at 0 and the engine ran for about 10 seconds after the first miss and me looking at the check gauges notice and then the oil pressure gauge. I assume it lost the low pressure side first and failed to fill the hpor. the truck is an 04 f250
That's not good. I assume that there wasn't a big puddle under the truck or you would have mentioned that. I'm also assuming that there is in fact oil in the engine. I don't have enough experience with the 6.0 to say for sure but I can't think of anything that would cause that big of a leak internally that won't require tearing into the engine to find. What do you think Scuffy?
