Rear Diff Additive
18K views 18 replies 9 participants last post by  jbj
Planning on doing the rear diff in the next few weeks. I was contemplating AMSOIL Severe Gear. Their footnote reads:
"[5] Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or
equivalent formulated to meet Ford Spec EST-M2C118-A
for complete refill of limited slip axles."
My owners manual says to add 4 oz.
Any ideas? I read one suggestion to add the gear oil, drive, see how the diff sounds/locks up, add friction modifier a to taste.
thanks,
JBJ
#3 ·
interesting I thought Amsoil recommended it's own friction modifier if you needed to add more than is already in their oil
I prefer to use a gearoil with no friction modifier already in them these clutches are already weak IMO
if you do buy the Ford modifier don't open it until you need it and if you don't use it all triple baggie it the stuff smells horrific
#5 ·
Just did mine, with same product the 75/140.. No need for diff additive with amsoil.. it is already incorporated in it. the diff additive is some differentials no matter how great the lube is can chatter, based on what type of limited slip it is. But on the 10.5 sterling in the 6.4.. No need. I dealt amsoil for a while, and spoke to technician at amsoil about this same question. My only suggestion is do it sooner than later :) also advanced sells a gasket to use so you don't have to solely rely on the silicone for sealant. I used permatex black, very small bead on the cover in the groove, and then a small bead on the gasket that touches the housing, and when I say small like 1/4" bead. I followed the recs snug it up, wait an hour then torque, then wait 24hrs before refilling. and worked awesome. Make sure you really clean the gears, and the housing, and the cover and the mating surface. Brake Kleen will be your friend. PS the gear oil stinks
#9 ·
Its actually amazing how many shops will drive it out 30 sec after bolting the cover back on and filling, hand you the keys, and off you go with the rtv minutes old lol. Whenever I have done it, I always do the diffs first then move on to an oil change, brakes, tire rotation, or some other maintenance to give the stuff a chance to set. Its rare for someone to come in just for the diff fluid... There is always trans, transfer case, oil change, fuel filters, and or some other repair being done.
#16 ·
Not a bad idea, but if I did that, I think I'd leave my gear lube/fill plug someplace that can't be missed before moving the truck. You go off to another job like brakes, tire rotation, fuel filters, etc. You wouldn't want to get sidetracked and forget your diffs are still empty.
The older you get, the easier it is to forget something. :senile:
#10 · (Edited)
#13 ·
^^^ IMO that's a terrible idea. Drain and wipe clean :thumb:
I just apply a healthy bead of RTV to the cover, smear it flat-ish with my silicone applicator tool (finger), let it sit maybe 30 min then stick it on. Haven't had one leak yet.
#15 ·
hammered mine with brake clean, got every particle of crap off, also a pain to clean bottom of housing because of the little pockets but took time and cleaned it all out... then filled diff, rolled very slow up the street to coat entire gear then off I went no issues.
#17 ·
Used royal purple and installed one of those $58 factory diff covers. Used grey adhesive silicone and put on with bolts slightly loose then tigntened them the next morning to provide some compression on the surface. Fill with the lube (did not add any addl friction modifier other than what is formulated into the oil) and works fine!
