Certainly didn't need me here - usually don't.
>> Itâs disconnected from both battery and alternator.
Hydro got here first. The factory cable must always be attached to the battery as itâs more than just an alternator feed cable.
>>Start the truck and voltage shoots to 14.8, 14.9, 15v, 15.1v peak WITH glow plugs on still.
I hope its regulator doesnât stay up that high unless you are using AGM batteries.
From another thread, the people at Mechman state that high voltage output concerns are an internet myth. So I guess all the work done at SAE and all the vehicle manufacturers have the limit at 14.4v, and regulating down to 13.8v generated that internet myth for about 50 years.
They say it won't boil, and most times, that's true. The voltage can be in the 15v range during the initial charging cycle, but it needs to taper down in the maintenance cycle of lead-acid batteries. Excessive high-voltage charging corrodes the plates, and you have shorter battery life.
AGM batteries operate at a slightly higher voltage, so they are more tolerant in that range; in fact, they should be. And on the other side, putting AGMs into a standard voltage-regulated system also does not get the best possible life out of them. With their low internal resistance, they transmit more energy to the need and can accept a higher current for recharging.
BTW, the Glow Plug Control Module has a circuit that will shut down powering them when the system voltage reaches 14.5v, so the glow plugs don't burn off the tips. So once the Mechman gets over that, there is no glow plug load. That little wire didn't make it past the initial wait-to-start initiation - 200a.
