Changing my oil cooler again because I believe my first one was a dud, stand up vendor replaced it no problem.
After changing the cooler my temps were as high or even higher than before.
I just want to make sure there isn't anything else that someone might know is causing this, because as fun as this job is, I have other things to do lol.
Something I just discovered was that when pulling the oil cooler out, it is normally completely full and oil goes everywhere.
To my surprise it was only half full.
Now a little background, I had a no start issue and not enough oil pressure showing when cranking, not even 100 lbs.
Pulled the IPR and ended up replacing with a new one with the same results.
Then I checked the ICP, which I should have sooner, but you know I figured I had screwed up and got dirt in the system.
Anyway the ICP had oil in it and it was my problem 😖.
So then I figured I was this far in I might as do the oil cooler again as I want to tow a boat to Florida.
So besides rolling over probably at least 2 weeks ago the engine hasn't had any oil pressure in it.
So my question, does the oil in the cooler basin drain eventually when sitting a long time?
