Hello all, new to the diesel world so thought I’d get some info and run some things past you guys.
I recently picked up a new to me 2020 F250 lariat 6.7 60000 miles 4x4 lifted on 37’s. Since I don’t necessarily know how well it was maintained and due to it not being under warranty, I want to make sure it’s in good shape.
Ordered all new fuel filters all oem since they seem to be the best. Since it’s out of warranty I did go ahead and buy the s&s disaster prevention kit for some peace of mind for the “cp4”. I understand to change them every other oil change and empty your water fuel separator about once a month. As well as run a fuel additive and try to steer clear from low sulfur diesel.
Next oil change I will do the oil and filter as well as tranny fluid. What else should I look for or what should be done at 60k miles.
Also realized my driver door won’t lock or unlock with the key fob or the buttons on the inside should I replace the actuator but I read somewhere that you have to reprogram the BCM. Not sure if FORScan would work for this but that would definitely fix my tire pressure light.
Any help or advice would be appreciated on maintenance or in general for a new diesel owner.
