Need advice on coolant filter
23K views 39 replies 12 participants last post by  StinkyPeteJones
I am about to order a coolant filter and need some advice. I was on eBay looking around and I see the Sinister ones going for 150-180. But what caught my attention was a kit from smeding for 85. They look identical. I was wondering if anyone has any input on the smeding kit. Also why would there be that big of a price difference between the two. They are both using the same filter so I can't see there being that big of a difference. Any input would be greatly appreciated. Thanks!
#2 ·
Don't know Smeding. Don't buy Sinister.
http://www.powerstroke.org/forum/6-...um/6-0l-performance-parts-discussion/974778-sinister-diesel-y-pipe-leaking.html
The big price difference is because the pieces and parts aren't really that costly or complicated. Lots of people build there own. You can find threads.
If I were to do it all over and buy one, I would prolly get this one:
XDP 6.0L Coolant Filtration System XD143
Like the lines.
That or check out NUC Motorsports. ...whose site seems to be down right now.
#4 ·
IPR Coolant Filter
I am going to give the same advise here. The IPR coolant filter is so far ahead of all the bypass coolant filters on the market.
There is no comparing the bypass filters to the IPR Full Flow coolant filter!!!!
You are moving 25 times the coolant through the filter then all of the bypass setups. I forget what I paid for the IPR but its worth every dollar for sure.
Don't waste your money on anything else, the IPR filter will clean up your cooling system and keep your oil cooler flowing at 100%
One last thing: get rid of your Ford Gold and put in some CAT EC1 coolant !!!!
#5 ·
My truck came with the sinister filter kit, its ok, id say its no better or worse than the XDP someone else mentioned. If i were to buy one myself i would go with the IPR one because of the filter setup, like mhatlen said, its designed to move more coolant than any other filter kit out there.
#6 ·
Agree with all of the above. I was originally thinking apples and apples. The IPR full flow is a nice setup and was/is always worth mention.
#9 · (Edited)
Yes. The IPR is definitely more of an investment. ...and the point about understanding the obligations of proper maintenance is a real deal. A neglected full flow coolant filter would be a helluva thing, indeed.
I think people need to stop beating around the push and explain that the price difference is the Sinister brand name and trademark.
Someone didn't drink enough blue Sinister koolaid, apparently... :)
I suppose that by explaining why the cheaper one was cheaper, I ignored why the more expensive one was more expensive.
I've never liked how the Sinister stuff even looked, so their Jedi mind trick never worked on me. ...but it seems to me like Banks. They have a right to try and take money from me. Just as I have the right to not let them.
Reactions: Heavy_GD
#8 ·
A coolant filter is a coolant filter. It's extremely hard to **** one up. If I had to do it all over again I'd get an IPR. If i had to do it all over again and I had to use a bypass, I'd build my own.
#14 ·
Don't worry, I keep that **** trimmed.
Reactions: Heavy_GD
#18 ·
I'm predicting right now that - within 24 hours - this thread had been moved to The Night Crew! and the OP has left for PSN...
Reactions: Canadian Mind
#20 ·
PSA. The Sinister of Forums...
#21 ·
haha, I admit that I troll over there just to read the comments... that is how I came to realize that we are...
... a joke.
And the "new" wave of mods are power hungry Dbags who think they are all powerful.
:rofl:
#22 ·
Lol. I saw that in the other thread.
"...power hungry who think they are all powerful..." Hmmm... That is either repetitive or redundant. I don't know which...
I saw what I think is a more accurate characterization at FTE once when I first started looking around about 6.0s. While they were debating how a bad FICM can cause coolant leaks to develop or some such nonsense, someone said - and I quote - "You should post this problem over on the ORG. Those guys know EVERYTHING."
Came right over.
#23 ·
Thedieselstop is a good spot as well. The culture there is a bit more stock-oriented, but it's a great group of guys.
Reactions: djmaguire
#24 ·
Back on topic... and assuming the OP hasn't left yet, I agree that the IPR system is the best available. It does have a high up-front cost, but you do not have to buy replacement filters, so you do recoup at least some of the investment over time.
@superchaos, The first couple times I cleaned my filter, along with blowing from the inside with compressed air, I used a metal scribe/pick to break loose the gunk in the pleats while under a running faucet. Subsequent cleanings have been easier and easier since the system is getting cleaner each time. Soaking in CLR is supposed to be pretty good at dissolving the crud, but I haven't actually tried it. I believe that letting it dry completely and using compressed air to blow from the inside would probably get a lot of it out too. Once the goo dries it doesn't hold together very well.
Reactions: Heavy_GD
#25 ·
Haha yep y'all lost me, I'm headed to nation jk jk. I'll stick with the org. This forum is a way to informative to leave. But I agree with the marketing which is why ask asked. Didn't want to pay for the name, and to be honest I didn't even know the ipr existed as bad as that may sound. I'll defiantly check it out. On a side note is it really necessary to filter that much more coolant or will the average filter do just fine? I have no prob paying the 250 if it's really worth it.
#26 ·
Hard to say on value. Again, apples and oranges.
Regarding full flow... Filtering everything gets everything. That's good. With a stock OEM oil cooler setup, the full flow filter is after the oil cooler, if I understand correctly. ...so that's not as good as if it were before because the oil cooler could still be getting gummed up. As before, the full flow filters require religious maintenance. The coolant circuit cannot be blocked.
In contrast, a bypass is just hanging off to the side grabbing about 5%. So, it is getting considerably less debris at any time, but over time gets lots. If it clogs, it isn't helping but it isn't hurting, either. It doesn't prefilter the oil cooler any more or less than the full flow, so - in that regard - it's a wash.
#28 ·
To expand on what dj said, the IPR setup can be plumbed a few different ways. I have mine tapped into the heater line feed and returning to the heater line return. As long as I'm not using heat in the cab, it is pretty much a full flow system since the inline valve has the flow stopped to the heater core itself. This setup does not affect the coolant running through the oil and EGR coolers. So, in this situation the religious maintenance is not as critical, but still needs to be done.
Mines like this, right now.
The other option is full flow as well, but would restrict cab heat if the filter became clogged, requiring filter maintenance, but still not restricting oil and EGR cooler flow.
If you opt for the manifold that pulls directly from the oil cooler coolant outlet, filters and returns to the EGR cooler, then religious maintenance is a must. As long as you monitor your deltas, you'll know when/if the filter needs cleaning.
This is with the manifold.
Edit to add: I have the manifold (thanks Merc82) and plan to install it at some point, just haven't had the time lately. It will be a little bit bigger job for me since I'll need to re-plumb back to the the factory coolant routing where I have spliced in the current hoses.
Reactions: mhatlen
#33 ·
Manifold Install
G8orFord I did install the manifold and I can say this about it: drink at least one beer before you start. The back side bolt is so damn tight to get the torx bit tightened up. I lost a tip to the intake manifold getting mine mounted. It's a tiny turn at a time but it's a good flowing setup.
Yes it's after the oil cooler but it's the last time the debris will ever go through it.
Plus it's a high flow spot so the coolant is really moving through that manifold. I myself have not seen my filter plug to the point where my oil cooler temps have climbed much at all. There is a lot of filter flowing and lots of pleats in it to plug up for that to slow down coolant flow.
One thing I did do to mine was I threw the orange anti-siphon rubber seal in the trash. I installed a simple rubber o-ring and that opened up the flow of it to 100% all of the time. The rubber that comes with it has a curve to it that reduces the flow, and it does reduce the flow....
My oil cooler ran 2-3* cooler once I installed the o-ring. The filter is a good one I had the Sinister bypass filter and it hardly filtered anything.
The bypass that it connects to is a very slow moving line, not comparable to what's coming out of the oil cooler.
One more plus with the manifold is it makes it fun almost to reverse flush the oil cooler. I myself did a cooling system flush as soon as I installed mine and the manifold made it so much easier.
I am a huge fan of the IPR filter setup it's so far ahead of any bypass setup that it's a mute point to compare the two.
If you can swing the cost it's the absolute best filtering system available today. It will clean that cooling system all the way, I hardly see anything in it these days.
#31 ·
The filter is washable. My filter has been in the truck for three years. How often does it need to be cleaned depends on the health of your coolant system. After a thorough flush I only clean mine while I'm changing oil just as preventative maintenance (its really not bad after 5k miles)......In the beginning, it may need to be cleaned more often. However, its a really simple process.
#32 ·
^^What he said. It really depends on how much crap is in your system. The beauty of it is you're getting that crap out quicker with the IPR setup. It may require more filter maintenance up front, but you end up with a cleaner system sooner. I'd probably check it after the first 500-1000 miles to see what it looks like and go from there. Remember, the filter itself is reusable, just clean and replace.
#34 ·
I got rid of the orange seal too... well, it's still there, it just looks like an o-ring now.
#35 ·
Orange anti-siphon seal
You know I talked with the guy who made the IPR filter and I told him the orange rubber was blocking flow and oil temps climbing 2-3*.
He argued with me about it, But as soon as I installed a buna o-ring i was back to same temps before installing it.
ZMANN does not like the guy one bit and it's because of the guys personality. He won't buy anything from him because he's a jerk lol
But I can say jerk maybe.....good coolant filter absolutely !!!!!!!
#37 ·
full flow is the way to go to prevent oil cooler blockage
just monitor your eot/ect temps to note any rise in eot and check the filter
I run the IPR filter right before the coolant feeds my BPD remote oil cooler that is as good as it gets
unless you eliminate the coolant to oil cooler and go a BPD air to oil and not have to worry about blockage
