im sure this question has been asked repeatedly but for some reason when you use "max" or "rpm" as a search qualifier on the forum search it returns that the word is too small to search.
But before i load any spartan race tunes and go and play. what is the maximum rpm under load that a mechanically stock 6.4 should be operated at.
its my understanding that the only tunes with factory safeties still in place are the non race tunes 210hp and less (no dpf and dpf) and every thing above 210hp has no defueling on safety parameters.
the spartan config file has the rpm warning set to 3200. and i would hit this warning on an untuned motor still running the factory tune at the top of the shifts at WOT. running the 210 im still into the warning on the shifts. but i would like to know what the stock redline is so when i load the race tune im within my safety margin.
