hi any help is appreciated.
ok so I did a base oil pressure test on my 6.0 and watched the oil fill the oil filter housing. It was fine.
I then did an air test on the passenger side of my 05 6.0 and sounded like i had nipple cup / injector air leaks.
Took that apart and resealed them. Put everything back together.
I shouldn't have done this until I made sure the fix was complete, but I then said to myself " I wanted to pull that low pressure oil pump relief valve " and see if it was sticking. It had some scratches on it but nothing serious. I put it back in, now the truck will not build the low pressure oil side. I held the relief valve down and did the starter jump prob 10 times for about 10 secs at a time and nothing in the oil filter housing. I took the relief valve out 2 more times cleaned it, put a magnet up the low pressure oil pump and found nothing.
thanks.
Kenny
thanks.
Kenny
