Low circuit 1,4,6,7 injectors. No power running on only 4cylinders
Early 04 6.0l. Driving perfect one day next day start her up 3-5mins later it sounded like a few injectors just dropped and major lack of power like barley enough to pull itself had to pop it in low and build boost to get it to move off a slight incline. Ran codes low circuit to 1,4,6,7 injectors popped up.
Changed ficm harness which I bought from DTPD nothing changed whiched also ruled the x3 connection being bad.
Next I replaced the ficm half shell which I believe contained the drivers for the injectors. Voltage prior to change 46.5-48 koeo as well as startup.after change 48-49v Again nothing changed.
Batteries changed bout 8months ago with interstate, new alternator 1yr ago. Egr delete. NO TUNES. That's why I have a BBC 496 for. BPD oil cooler.
rather than throw more money at the problem I actually would like to know if ficm or injectors are at fault here. I find it odd 4injectors would go bad at once and it being 1,4,6,7 at that.
Would appreciate the help and knowledge from any of you 6.0l gurus. out there. Thanx
