Ipr wiring trouble
1 reading
9.5K views 11 replies 4 participants last post by  Schmidty78
Hello all,
Just joined and starting off with a question. 2006 F350 CC LB 4x4 4.30 Auto DRW 115k no start issue. Long story short, Ipr shows 85% on scan gauge but cranking only generates 300psi at best. Manually apply power and jumps to over 700 instantly on same scan gauge. Might have Ficm issues too, but waiting on parts so I’ll save that conversation. Has anyone narrowed down this power to the Ipr issue? I’ve chased wires and nothing visually, but haven’t load tested. Fuses are all good and this whole thing started when truck died while driving. Started back up a few times, but nothing afterwards. Gut is saying a bad wire based on the way it died. No issues with anything prior. Thanks in advance.
#3 ·
So now for the longer version. The ICP was replaced first and then the pigtail. I tried it with the ICP both plugged in and unplugged with no difference. I’ve replaced the IPR but not the pigtail for that. I’ve done continuity tests for both sensors and they pass that simple test. Originally the FICM was showing that it was working fine but through my attempts to get it started it lost sync and power. I do the power test at the Ficm and it shows between 48 and 52 V. We hook up the fancy computer and they are unable to fire the injectors. It appears the power side lost communication with the logic side of. So the ficm was sent off for testing. The only common denominator that I could come up with was the PCM so it was replaced but nothing changed. Now I’m left with the only common denominator being what I originally thought and the wiring somewhere having an issue. I’ve checked all the known chafing points and have found nothing. All of the contact points between the harness and the PCM looked to be fine. Thank you for taking the time to read into my issue.
#6 ·
What are you getting when you crank it for 10-15 seconds? I'd pull the IPR and inspect/clean. Remember, IPR is a commanded signal with no feedback.
-jokester
#8 ·
Does your oil pressure gauge move on the dash when you're cranking?
What is your battery voltage, RPM, ICPv KOEO and while cranking?
You said air test was done...i'm assuming you found nothing? Did you apply 12v to close the IPR when you were air testing?
-jokester
#9 ·
Yes, gauge moves, also pulled oil filter and it fills. Batteries are over 13v each attempt. Rpm’s are in range. Not sure what ipc volts are, but if unplugged, reading shoots up. I have not attempted air test while cranking, but when doing air test and applying 12 to Ipr air immediately stops going through oil pan or wherever it bleeds off and holds until 12v is removed.
#12 ·
After 3 months of what seemed like guessing, I went with my original thought and bought another Ipr valve. 10 seconds later, fired right up. This was also after a rebuilt Ficm. Apparently I fried the Ficm while trying to start it or hot wiring the Ipr. Stumbled a couple times getting the air out, but 30 minutes later, runs like it always had. I don’t recall where I got the replacement Ipr, but got the new one from xdp. Good reminder to use quality parts. Thank you all for the help. Let me know if you have any questions. I would love for this post to help someone else
