Ok, so I installed a reman gearbox due to play about a month ago along with ball joints and a hub assembly. About 3 days ago, I lost power steering. It was very hard to turn especially trying to park. I did notice if my foot is on the brake is when it gets harder to turn. It is to the point that my wife cant turn the wheel. Even after I take my foot of the brake it is still hard until I throttle up a bit, then it gets easier. I replaced the pump and I thought that was it. Nope, same problem. I took the pump off and replaced it with a different reman unit. Same problem. Would a bad hydro boost unit cause these issues? 02 Excursion 7.3
