How to adjust the steering box
1 reading
102K views 20 replies 12 participants last post by  StrokenBoost
Hey guys,
I saw that there are a few threads on how to adjust the steering box but to save a few people time i figured i would list the tools needed or rather the ones i used.
Tools:
3/16 Allen wrench
17mm box end with ratchet style end
5/8 box end and 11/16 box end for added leverage
paint pen
1. Locate the adjustment screw on the top of the steering box. There are 4 bolts holding a little plate in place and the screw is in the center of that. You can see it if you look directly to the right of the lower radiator hose that is on the drivers side of the truck on the outlet of the engine. You can also see it from the bottom of the truck looking up near the fan shroud. There is a little notch in the shroud that gives you a little access to the screw.
2. Mark the end of the screw were the 3/16 allen head with a paint pen.
3. I took the 17mm nut completely off to make getting to the 5/8 nut easier. You could just losen the 17mm nut and then the 5/8, it is up to you. Once both nuts are lose make sure that the screw didn't move. Now take the 5/8 wrench and then turn the 3/16 allen clockwise when viewed looking down. I turned mine a full turn and then took it for a quick test drive. I did notice that once the 5.8 nut was lose, a little bit of fluid came out. I am hoping that now that the nuts are back tight that it doesn't continue to leak.
4. Long story short, one full turn of the screw solved my sloppy steering issues. The truck has nearly 100k on the clock so a little slop was to be expected i guess.
Hope this helps a few of you with steering play.
I plan on replacing the box when it runs out of adjustment or i find $500 to send to Redhead so i can get a new one.
#3 ·
you bet, i was really impressed on how much it helped. Now i just have to get used to driving without constantly turning my hand back and forth.
Does anyone know what happens if you tighten that screw too much?
#4 ·
I'm still struggling with this! I was going to adjust my steering box, but warranty ended up just replacing the whole thing. But now I am constantly over correcting and what not. just out of habit. lol
#5 ·
yep same here. i am guessing it will go away with time. but now i really swerve all over the place. :)
#6 ·
I was told that the excessive play was because it's a TRUCK and not a car. What could I use to determine if it's excessive or not. I sure would like to have the dealership eat this one.
#9 ·
You can over tighten it. It will have tight spots and return to center issues.
#11 ·
1/4 turn at a time and take it for a spin. I wouldn't do more than 2 full turns.
#13 ·
Bit curious bout this as well. He made it sound pretty easy?
#15 ·
I did mine last weekend. Its a ***** if your arms are bigger than a 12 year old girls! You gotta squeeze your right arm between intercooler and coolant hoses, balance with left arm and hold flashlight with your teeth to see what your doing. I did get it done in bout 1.5hrs. Still have bruised bicep and forearm. The mental trauma is fading though.
#17 ·
That's the right part. Remove the top nut completely. Use a grease pen to mark the location of the allen screw. Break loose the lock nut holding it. It usually moves the allen screw with it is why its important to mark its location. I adjusted mine 1/2 turn in. The hard part is trying to move the allen screw without moving the locknut, all with one hand. A person helping through the wheel well would make it much easier.
#19 ·
I have a 2014 with a 4.5 inch lift and drop pitman arm. It just seems like there is way more play in the wheel than their should be after the lift was installed. The pitman arm is dead on balls tight, no issues there.
I had someone wiggle the wheel back and forth while I looked at the input shaft and pitman arm. In doing so, I see the steering input shaft going back and forth quite a bit and I see very little movement of the pitman arm. So the play is clearly in the steering box. The truck only has 22K on it, about 10K of that is with the lift.
Should I try adjusting the steering box? I just don't want try and solve one problem and create another.
#20 ·
I would lift the front end first and see how much play is actually in the box. You can adjust it, but you don't want to adjust it too much. How long did it take from being "good" to being "bad"?
Mine was similar and ended up completely breaking (I didn't adjust it). I replaced it with a Red Head steering box.
#21 ·
I just did this on a 2014. It felt really sloppy. Prior to adjusting you could wiggle the wheel back and forth at least 30 degrees without even moving the pitman arm. I could see the steering shaft going back and forth with zero movement on the pitman arm. Now its down to about 6 degrees until the pitman arm moves. I just hope I didn't make it to tight. I found that a 1/4 turn didn't do anything I end up doing about 1.5 turns in before it felt like it was taking up slack. I lifted the front off the ground and even disconnected the stabilizer and moved the wheels back and forth fully to both sides. I didn't hear or feel any binding.
Has anyone had any issues doing an adjustment on the 2011-current trucks? I hope I can keep it the way it is, because it feels so much better now.
