How long to purge?
1 reading
3.5K views 11 replies 4 participants last post by  ridiculously_necessary
Well finally got my DIY system going. So far so good. How long should I be purging for though? My purge valve is a hydraforce switching valve which has 1/4 ports. I tried purging for approx. 30 seconds but after doing that a few times I noticed the diesel fuel gauge dropping so I figured that was too long. Now I have tried purging for 10 seconds & then running the engine for another minute before shutdown. Seems to be better. I don't have sight glass so I am just guessing if I have purged enough.
How long does the vegistroke purge for? How long are you DIYers purging for?
#2 ·
Describe your system.
How is the system configured?
If you have a purge valve should I assume you are running a regulated return?
Here to help- just fill in the details. :thumb:
#3 ·
Well ok. My conversion is based on the vegistroke checkvalve system. Check valves in the heads on the diesel side, plugged ports in heads opened up & veg is fed into the heads that way. 1/4" SS braided hose for the veg lines to the heads that are connected to a tee that goes to my FPHE whcich is located on the firewall next to the brake reservior. From FPHE I have TIH ( 3/8 aluminum tubing in 3/4: HH,) which runs back to my davco 322 filter head. I have 3/8 check valve right before the davco. Right before the check valve is a tee where the TIH from FPHE terminates & the hydraforce switching valve is plumbed for purging. Then a line returning to tank from the purge valve. Continuing to head back from the davco is my Fass HPFP internally regualted fully adjustable pump which I have set to 75 psi. Then another TIH which goes back to my 60 liter poly tank with hotfox pick up. Everything is plumbed with coolant of course & I also have a auxilliary coolant pump plumbed in the return coolant line for better coolant flow. I also installed a 203f t-stat.
So far it is working very well. I have vegi temp, pressure & fuel gauge in my pillar pod. I go by the factory temp gauge to know when to switch over. I wait until it is fully up to temp before switching. I am seeing veg temps of 180-190f on the road & 160 when ideling( no I don't idle for long periods on veg). The temp gauge is plumbed between the FPHE & the tee for the SS lines to the heads. That's as close as I could get it to the heads. I have had a couple of leaks to deal with from the tubing in the TIH but I hopefully have fixed them so they won't leak again. Time will tell with that though.
Like I said so far so good. I just want to make sure I am purging the correct amount. Not too much but definetely not too little.
#4 ·
Not to sound like a dumba$$, but I read all that and cant figure out why the hell you even have a purge valve. If the systems are parallel, just use a relay to switch the pumps, because on a dead head system the VO will burn off and be replaced to D2. No need to purge that way. Normally 60 seconds on a deadhead will be adequate. I run a RR and give it about 30, and it smells like D2 when it fires up on cold start. Sorry I could not help more.....
#5 ·
You don't have to have a purge valve but if you don't & just switch from veg back to diesel it takes a very long time to burn up the veg in the fuel rails & injectors before you can shut down. Like 5 to 7 mintues. Thats what I have been told by many. With a purge valve you can flush the veg out of the fuel rails in seconds & then run the engine for about a minute to burn up the veg still in the injectors. That is how many systems are set up including the V3.
#6 ·
5 to 7 minutes is a long time, it should only take 30 to 60 to clear the rail i would think. anyone know the diameter of the rail? i would like to know how much fuel is in there...
also, what you may have read is people who have systems that pull veg into their fuel bowl. you need a goot 5 to 7 minutes just to dilute the veg enough to reduce cold start voscosity. never get a true flush. i have one of those, not for much longer thoguh.
since you have a purge might as well use it. here are my thoughts, install a bleed screw or pull a line on the head and feed into a jug of some sort. have a buddy operate the key and time how long it takes to feed a sufficient purging amount of D2 into the jug. that should get you a resonable number.
#7 ·
Purge if you like, it will definitely be quicker. But, 5-7 mintues? NO WAY. I run two deadhead systems, and the check valves are back off the heads just a bit. Even then, I run D2 under two minutes, probably closer to one.
#8 ·
i know diesels use hardly any fuel ideling, so i will be flushing (deadhead) about 1/4 mile from the parking lot and driveway.
#9 ·
I'm just going by what I have been told & no the people that told me this have the same setup as mine. I know the vegistroke has a purge valve. Anyone know how much time that is set for?
#10 ·
Clay would know.
I have been thinking about this all day. It has been about a year since my last V3 install and I cant reacall. With check valves in the service ports, I cannot for the life of me figure out how any D2 could ever get back to the module on the V3-thus I still maintain the engine consumes the VO while being replaced by the D2........:dunno:
#11 ·
This the discussion I have going on Frybrid about this.
Purge time - Forums
Your probably right about 5 to 7 minutes being way out to lunch on my type of setup. I got that confused with conversions that both D2 & VO go through the stock filter. But purging is suppossed to cut down switchover times alot & better insure the fuel rails & injectors have no VO left in them. Again that's what I have been told & the reasoning behind it.
