EZ Lynk Tyrant Hiss VS Rumble
1 reading
33K views 13 replies 7 participants last post by  joebuck
For those running these tunes what is the actual difference on the road between the two? I know they sound different at idle for sure but they also sound different when running so i am trying to figure out which ones is best on the turbo. What exactly are they doing to the truck when running?
#3 ·
It cant be just idle as it sounds quite a bit different when running as well
#5 ·
Just a flopro race pipe with stock rear half. It is significantly louder at higher rpms that rumble I've noticed
#7 ·
It's a 15 not a 17 and I will try to take a video but my phone wont capture it real well I'm sure
#8 ·
Also I have noticed that kybtruck does not make that loud "rick flare WHOO" when I let off the throttle like most 6.7, I wonder why that is.
Reactions: HeavyAssault
#10 ·
Because you have a different turbo than the 11-14, they make the loud wish sound from there wastegate but your turbo is MUCH stronger and makes more power! But just not as noisy
As for the tyrant rumble vs hiss it’s just a vane location of the turbo at idle it’s either open or closed (rumble=open/ hiss=closed) that’s it not woot more to it, watch your vains % on your monitor during idle in the different tunes you will see the difference
#9 ·
Or you could ask who you bought the tunes from to explain the difference to you.
