Early and late 2004 changes. Need help with which waterpump
14K views 17 replies 5 participants last post by  harlo
I was wondering if anyone knows exactly when the waterpump changed to 100mm? My truck is what I have always thought to be a late 2004. I called dieselsite to order a waterpump and they said if the build day is before 07/2004 the only way to know forsure is to look at the high pressure rails to see if they are straight or wavy or pull pump and measure. But I'd like to have the pump here before I tear it apart.
What I do know about my truck is,
4EB vin
Build date 10/22/2003
Icp sensor on valve cover
Cast iron hpop cover
Had square egr cooler
Anyone have an idea what pump I should have?
#18 ·
Well I finally got around to pulling the pump out. It measures 99.84mm/3.93 inches. So it does have the bigger one. I also found a stamp on it 10/1?/03 so it is still the original. I'll be ordering the dieselsite pump in the morning.
#17 ·
Link worked. Interesting to see that. Keep us posted on what you find.
#16 ·
#15 ·
Not yet, been to busy. Hopefully tomorrow or Monday.
#14 ·
Did you order it?
#13 ·
Thanks everyone! I figured it was the newer pump but they had me second guessing. Wanted to make sure.
#12 ·
I don't think that's the info he needs.
#10 ·
I just gave Pinky at BPD my vin# to make sure I got the right water pump from them.
#8 ·
No, if it is after 9/2003 and you have the square egr cooler you have the 100 mm pump.
Reactions: djmaguire
#5 ·
He already answered that. That's not the determining factor though so the point is kinda mute.
#3 ·
Look here at the BPD site for thier water pump.
#2 · (Edited)
You have a post 9/2003 build. There is only 2 pumps. Pre 9/2003 and post 9/2003. My truck is a 2004 with a build date of 9/22/2003. Mine is the early build.
#6 ·
Are you positive that that's the only date stuff changed?
I even mentioned what BPD site said, my build date, and that i know its a late build and the still recommended i make sure before ordering. They said some 2004s are kinda on there own.
