Status
Not open for further replies.
Early 99 to 2000 7.3L Swap
15K views 33 replies 13 participants last post by  t-ray-4ray
I have 2 trucks, one is a early 99 F250 that is rust free that I just bought and the other is very rusty 2000 F250 that I am going to sell (i have a third truck, the truck in my sig, but it will be involved in this project!). I just pulled the engine out of the 2000 F250 to replace the oil pan and ended up going through/replacing/rebuilding just about everything on it. I also just rebuilt the trans in it. I want to swap the motors and transmissions in both trucks. Here is where I'm having some difficulty:
If I pull the engine out of the 2000, can I leave the engine wiring harness connected (only disconnect the big square plug by the drivers valve cover) then drop it into the the early 99 and plug the big square plug from the early 99 back into the 2000 engine's wiring harness? I know I will have to swap PCM's but what about anything else?
Is there any differences in the transmissions (both auto trans)? Or should it just be a plug and play swap there?
Save
#34 ·
I swapped a early 99 engine into a 2001 truck with a auto trans and just left the wires on the engine and I also didn't swap the computer because I went with a hydra 17 pos chip I have a build thread
Save
#31 ·
It may or may not be depending if it had been replaced. ( I always use IDM 120 when replacing because they are cheaper)
Don't worry because any one of them will run fine. And if you want to mod it just simply read the sticker.
There is little to be gained from a modified IDM unless your injectors are worn out.
#30 ·
Well, now I am more confused than ever lol!! Does the E99 have lower voltage idm than the later trucks or not? I thought everything I have read that they are different, therefore they both require different resistors to do the same 140 mod? Sorry if I'm just not getting it, wouldn't be the first time!
Save
#24 ·
:doh::doh::doh::doh::doh::doh::doh::doh:
just stop.... please stop
the I in ohms law is current. It's always current. There is never a case where it's something different.
this thread is about a motor swap.
Save
#27 ·
Exactly.
bjesse, mentioned to swap IDM's from a newer truck also, in which the IDM's output are all the same. But may people confuse the IDM part numbers (100,110,120) as voltage output. Even though in order to do the infamous 140v IDM mod takes different resistors for different IDM's. Which is where i brought up ohm's law.
#21 ·
Ohms law has different formulas for AC and DC. DC has resistance, AC has impedance. The resistance(impedance) in AC is different because of moving magnetic fields. Also, with AC, you have to take into account inductance, not so for DC.
#19 ·
Hucory,
I guess I'm just going to have to stop. The link you posted explains it ohms law clearly and it is exactly what I stated earlier. I'm not sure where the confusion comes in but if Impedance is measured in ohms just like a resistor and current is measured in amperage then they are clearly not the same thing.
But I digress.
#17 ·
Hucorey,
I'm really not trying to come across as a smarty pants but impedance is the opposition of current flow in an AC circuit. That is it's relationship with current but it is defiantly not the same as current.
Mathematically Ohm's law is: I=E/R; E=IxR; R=E/I I is current; E is volts and R is resistance
Again, In no way am I trying to come across as a know it all.
This is the one thing I know a little about...and the intricate details of a woman's mind...NOT!!
My apologies for being part of the hijack.
#15 ·
Hucorey,
A diesel mechanic I am not. An electrician I am. I think you are a little bit confused on the Ohm's law thing. Impedance is basically resistance in an AC circuit. Ohm's law is: E=IxR where E is volts I is current and R is resistance. When you series batteries you add the voltages and when you parallel batteries you add the current. As far as resistors on a circuit board if they are the same size resistors, when two are in parallel they have half the resistance as one and when two are in series they have twice the resistance as one.
#7 ·
My plan was to disconnect the engine wiring harness from the truck and leaving it connected to the engine (on the 2000 engine the wiring harness will still be connected to the AIH, valve cover gaskets through to injectors/glow plugs, HPOP, IPR, ICP, fuel bowl heater, etc.). When I drop the 2000 engine into the early 99 truck, will the main harness (big square plug) plug right into the 2000 harness and function properly?
Save
#5 ·
Please, do explain what you disagree with.
Save
#13 ·
diffrent inj's and tunes, diffrent trans shifting strategy. As far as physial diff, inj's hpop, intake runner size, turbo, turbo mounts, intake heater, intercooler pipe size (turbo side). but to the op, as long as you switch turbo and all and pcm and dont need/mind not having intake heater then yes it will swap :thumb:.
Edit: also forgot turbo inlet size and air box are also difftent. As is IDM (E99 has 110V output), same box/connector but diffrent voltage any how it will run just fine though.
Save
#3 ·
Yes, you can drop it right in and connect everything and start it. There's no need to swap the PCM.
Save
Status
