I did alot of research on these forums before I bought my exhaust system in June. I learned that it all boils down to this:
For normal driving and towing, the performance difference from the stock 3.5" system to a 4" system is huge. The performance difference from the 4" system to a 5" system is rather negligible other than the sound/tone unless you run your truck near its limits such as racing or pulling where every little bit counts and you are running a larger turbo and injectors.
I decided to go with a Diamond Eye 4" stainless steel turbo back exhaust kit with muffler. I have a couple of friends who went with a straight pipe and ended up buying a muffler due to the whistle which is cool most of the time but annoying when driving through a quiet campsite or neighborhood late at night. I left the CAT off but held onto it in case I ever move to a place where I need to have one.
The attached pictures shows the difference between the stock and 4" system. It installed really easy in my driveway. I had my daughter help with installing the first pipe off the turbo, she held it up from below while I loosely installed the v-clamp to the turbo. After that, it was no problem.
It made a very noticeable difference in my EGT's when towing plus it sounds awesome when under load.:thumb:
