Greetings all,
I’m a shepherd our herd eats fire fuel around peoples homes in Southern California. 1999 7.3L F350 was running and then would just turn off while driving, not like it’s out of fuel just turn off, but then would only start cold and then die after a few minutes. And was getting these codes:
P0603
P1000
P1118
P1391
P1393
Checked all fuses and replaced
7.5 amp Trialer left lamp
16 30 amp Trailer tow battery
24 30amp power distribution box (wiring harness looked like it may have shorted it out.
Wait to start and normal cranking sound, no start.
P0475
P0603
P1000
P1118
Codes remaining:
P0603
P1000
Replaced wiring harness off eBay because I couldn’t find the part number for OEM : crank no start.
Codes coming back
P1391
P1393
P1000
P0603
P1000
P1118
P1391
P1393
P0475
P0603
P1000
P1118
- Replaced CPS OEM: result crank no start ; tested another new CPS after trying all: crank no start
- Replaced MAT sensor OEM: result, P1118 went away, crank no start
- Replaced new Fuel Bowl Filter OEM
- New Batteries
- Charged batteries after starting
- Used engine heater
- Hpop reservoir is full
- Oil level is sufficient: oil filter and oil changed within last 1000 miles
Codes remaining:
P0603
P1000
Codes coming back
P1391
P1393
P1000
- Tested Glow Plug resistance at valve cover got four pins on each within spec with .8-.9 Ohm
- Tested relay, here click, witnessed voltage power and then shift accordingly
