Classic ICP problem?
1 reading
12K views 14 replies 4 participants last post by  bismic
Removed the EBP sensor and cleaned it out, cleaned out the EBP port. Intermittent revving/bucking when idle or driving. Next step is getting to the ICP and seeing if it’s bad. Would this be symptoms of a classic ICP failure? Including video...
6.0 Powerstroke ICP Failure?
#5 ·
Anything todo with your battery light problem??
#7 ·
Just removed heat shield and disconnected ICP connector. 1 there wasn’t any heat lume around the connector like there should be, so seems to me the ICP has been replaced before. Maybe the connector/wires are friend because of this? Anyways going to let the truck warm up and test drive to see if I get the revving/surging issue.
765676
765677
#9 ·
Dielectric grease and dirt ...no problem here /sarcasm
Electric cleaner and wash all that out -- fresh dielectric -- and keep it clean -- DONT use brake clean
