Our old buddy Bill is not entirely wrong about the CCV system and turbo oil usage -- anything that causes undue pressure in the crankcase will make the turbo seals more likely to pass oil -- as well as gasket and crank seal leakage
Undersized vent tube, excessive blow by, or just the length of the vent all play a role in crankcase pressure
The factory system creates a vacuum on the crankcase(depending on air filter restriction), which helps pull moisture from the crankcase as well as lessening oil leaks on the engine
it has long been known that a vacuum on the crankcase is beneficial
A catch can system would be a good addition to the system, but otherwise leave it factory
If you are getting oil out of the ventilation system, there is another problem that needs addressed -- changing the CCV is only a band aid
