Hi everyone, I have been looking into doing the CCV delete and came across the video of the power stroke help guy on youtube. He said that doing the ccv delete will ruin the turbo seals. Is this true?
SO how on green earth can a CCV delete result in pushing oil past seals on the turbo? The lubrication circuit is sealed for the most part to include the oil filter.which makes it necessary to use a scavenging system to give the crank case sufficient vacuum to prevent oil from pushing past the turbo and valve seals
Yet you do not say WHERE you would connect your "system" to the crank case.If you're running a bigger turbo, aftermarket intake and intercooler piping I'd run it with some sort of scavenging system to help keep less than atmospheric pressure in the crank case.
The air in the crank case still has to make it through a single hole in the valve cover, down a long tube (depending on which kit you get the fitting and tube are likely undersized), past a filter and into the atmosphere. It's entirely possible you can make more pressure inside the crank case than is capable of being vented at any given moment. There are other problems with some of the kits that just vent the valve cover through an AN fitting and tube directly to atmosphere like oil mist (an air oil separator or catch can with a baffle can fix that) and smell. I like that Nolimit provides a kit with a venturi that actually provides negative pressure to the crankcase and puts the oil mist directly into the exhaust. No Limit Catch Can Kit With VenturiBut there IS pressure created under the valve cover from the blow-by of the piston rings hence the OEM CCV. When the valve cover cavity is directly vented to the atmosphere HOW does that pressure now "push" oil past the valve seals????? It can't, it just vents.
I think we're getting some wires crossed here.SO how on green earth can a CCV delete result in pushing oil past seals on the turbo? The lubrication circuit is sealed for the most part to include the oil filter.
Ray Hall Turbocharging - Turbocharger Facts and Myths
Fact Turbocharger seals do not seal engine oil pressure
Fact Turbocharger seals are there to seal crankcase pressure.
Fact Turbocharger seals are made of steel, not rubber. They are a steel piston ring.
Fact Turbocharger seals do not fail. Bearings fail first then the seals leak.
Fact You cannot BLOW a seal, no matter what you do.
Fact You can easily damage the bearings, and then the seals will leak.
Fact Incorrectly designed crankcase breather = oil smoke
Fact It you have oil smoke, then you need to fix the oil drain or crankcase breather.
Crankcase breather size is dependent on the number of cylinders. Engines with two cylinders need huge breathers. 30 to 40mm are needed. On a four cylinder engine you can use 19mm (3/4") in most cases. Catch Cans are a major cause of oil smoke. They restrict the engine breathing. If using a Catch Can, the hose and fitting sizes need to be doubled.
It has been my experience over the past 17 years of owning highly modified turbocharged vehicles that all of the above is true.Common Turbocharger Problems
Engine Breathers:
Also, oil leaks in a turbocharger may be the result of the crankcase breather system. Either atmospheric or positive ventilation systems may not be large enough to handle the somewhat higher "blow by" which exists in turbocharged engines. It is recommended that the engines breather capacity be increased when a turbocharger is added. Even when the systems capacity is adequate, the elements in the systems breather will become partially clogged through use. Also, the breather may become clogged with mud or sludge in winter or under snowy and icy conditions. These conditions will cause positive pressure to build up in the crankcase. If this occurs, it will restrict the oil from flowing down the drain hose and into the crankcase, causing it to back up to the bearing housing.
I'm not selling anything, just offering information. I would like a system that connects to both valve covers, which are considered to be a part of the crank case. The 6.7 specific systems only attach in place of the filter on the drivers side head.Yet you do not say WHERE you would connect your "system" to the crank case.
Well which is it....You support Bill or you don't.....Either you agree a CCV delete is good or it's a waste of time.????? Which is it? Just be clear since your statements are not clear at all.I DO agree with his assessment of CCV deletes. If you're running a stock turbo and block I don't see the point.
I wouldn't do it, and I haven't seen any evidence that it's necessary.
I'm not making the argument that a CCV vented to atmosphere will ruin turbo seals on a 6.7 powerstroke. I'm stating that I don't believe a CCV is necessary with a stock turbo and stock boost pressure on a 6.7 If I didn't make that clear before, I apologize.
.It has been my experience over the past 17 years of owning highly modified turbocharged vehicles that all of the above is true
I appreciate the point you're trying to wiggle in here. The OP was looking for feedback on Bills opinion. I immediately recalled the video because of the claims that he made in it were somewhat unclear and could easily be misunderstood. I feel I've been clear and consistent in conditions where CCV modifications/deletes are appropriate, where they aren't needed, and posted references to further reading for anyone else that's interested in the subject. I haven't deviated from that at all as you accurately quoted. I'm not sure what else to say, based on your last post it seems like we mostly agree with each other when it comes to where CCV modifications add value. For anyone else reading this thread, I encourage you to search for honest feedback given by owners of the common 6.7 Powerstroke CCV delete kits, then make an informed decision on what kit makes the most sense for your build.Well which is it....You support Bill or you don't.....Either you agree a CCV delete is good or it's a waste of time.????? Which is it? Just be clear since your statements are not clear at all.
