Can a bad FICM cause engine damage?
9.8K views 2 replies 3 participants last post by  JustinOOO9
I bought a 6.0L ford CHEAP with a bad engine for a project. I am a Cummins guy turning to the dark side so I've been surfing around this forum for several weeks now gathering information on the 6.0L. Most everyone here seems very knowledgeable and friendly so I thought I would pose this question.
This 6.0L has two bad pistons. #4 piston just looks like it had been over fueled and has melted the piston. #1 however dropped a valve and has some pretty major carnage. I can't quite tell for sure but I think this piston was over fueled also and that may have contributed to the valve dropping. So my thought was these failures must be related as it would be an amazing coincidence that these two cylinders failed at the same time from two separate causes. Is it possible a bad FICM would cause this kind of damage if run to long? This pickup was BONE STOCK with 170,000 miles. Didn't even have a programmer. Was used to pull heavy horse trailers. Pretty sure he was towing when the those cylinders gave up.
Any thoughts on this or suggestions on any thing else I might have missed?
-=Stone Rhino=-
05 Ram 3500 A4 100hp II injectors
04 Ford 6.0L A5 "ground up engine rebuild in progress"
