Best additive Fuel and Oil
15K views 21 replies 13 participants last post by  FDB
Hey folks I'm sure this is a topic that has been tossed out over and over . Please share what product's you guys are using that has yielded good results.
Archoil has a kit which consists of 9100,6200 fuel treatment, and 6400fuel system cleaner. I know that the 9100 is very highly recommended. Are the other two products producers of good results? there is so many products out there . I run diesel clean in my OTR Tractors for years Half gallon in each tank and ride. recommendations welcome..
#6 ·
For me personally...I run:
OIL: Mobil1 Turbo Diesel Truck 5w-40 and Archoil 9100
FUEL: OptiLube XPD year round
-jokester
#11 ·
OK. Sounds dumb but I stopped using Diesel Kleen simply because the cap doesn't seal well. I keep it behind my rear seat and if it happens to tip over, it seeps all over and stinks it up. I don't have a tool box in the back or it'd live there but I wouldn't be thrilled about it leaking in there either. So I just stopped using any additive. I've been looking at the archoil but man, they're proud of that stuff.
Anytime I look at the parts store isle, it all looks like rows of snake-oil and miracle juice (MEGA-ULTRA to the EXTREME Max Go-Go Juice). Can't tell if it's male supplements or Diesel Additive (Faster, Stronger, More Power, For Ultimate Experience use the whole bottle) so I just walk away intimidated and self-conscious about the size of my truck.
#12 ·
I know what you mean. I have a tool box, so I dont have to worry about that. But it is an issue when it comes to sealing it. I ended up putting a crate in my box with my extra oil, antifreeze, etc. Keeps it from falling over and spilling
Sent from my SM-N950U using Tapatalk
#13 ·
They did change the seal at least on the grey summer and white winter bottles. Also I always squeezed a tiny bit of air out and screwed the cap on to create a vacuum. It seems to hold much better and I have some white left over from last winter that still hasn't leaked. I have a small plastic container not sealed like a mini milk crate to keep things upright and no leaking since over a year now.
#14 ·
I used to fill "syringes" with screw-on caps that were the perfect size for a full tank treatment. I kept them in a box behind the back seat. I've since gone to carrying a small 'crate' to house a few containers of various fluids, and store it in there.
I've been in those shoes. Jumping up into the truck on a hot AF Florida day only to be hit in the face with the fumes from a tipped DieselKleen bottle. That smell lingers for-ev-er, regardless of how well you try to clean the area.
#15 ·
Correct me if I'm wrong but I believe the owners manuals state NOT to use any diesel additives.
Use a Top Tier Diesel fuel and high quality synthetic oil, changed every 4-7k depending on your driving conditions and towing and that may be the best way to go.
#18 · (Edited)
I just bought my '05 about 6 months ago, it had a fresh oil change of unknown type at the time of purchase. I finally rolled over 5K miles on it last weekend and changed the oil- Rotella T6 5W-40. Added in the Archoil AR9100, as well as OptiLube XPD to the fuel. Took it down town and back. The very next day, I could tell a big difference in the way it started up and ran. Much quicker easier starting, smoother and quieter running. I am a believer in this combo, as suggested by many others here.
My odometer shows 120K miles, but it's got a Ford remanufactured (w/studs) engine in it, and I haven't yet contacted the Canadian dealership to see when that was done. U.S. stores can't pull Canadian warranty/service work apparently. I doubt the original only lasted 15K, so I feel pretty good knowing this very likely has far less than 100K on it. Anyway, sorry for off topic.
#19 ·
I'll always be an Opti-Lube fan, great product and great people.
Sent from my SM-A505U using Tapatalk
#21 ·
I use Amsoil and Optilube XPD
#22 ·
Long read but worth it.
