ATF in your Diesel
1 reading
2.8K views 14 replies 10 participants last post by  3pointstar
Hey guys, Lately I’ve been seeing a lot of people on social media adding automatic transmission fluid (ATF) to their diesel fuel. I did some research on the subject, and I think it’s really important for us to understand that this is not a good idea.
While some people claim it helps with injector cleaning or lubrication, especially in older engines, modern diesel systems are much more sensitive, so I’m leaving this information. You guys decide for yourself.
Can You Add Transmission Fluid to a Diesel Tank?
Adding automatic transmission fluid (ATF) to a diesel fuel tank has become a trend on social media platforms like TikTok and Instagram. However, it's important to note that this practice is not recommended by vehicle manufacturers or automotive experts.
Why Do Some People Do It?
In the past, some owners of older diesel vehicles added small amounts of ATF to their fuel with the idea of cleaning injectors or improving lubrication. This was based on anecdotal experience-not scientific evidence.
Is It Safe for Modern Vehicles?
No. Modern diesel engines, especially those with common rail injection systems, operate at extremely high pressures and have very precise tolerances. Adding ATF can:
1- Clog or damage injectors due to residues and additives not designed for combustion.
2- Harm emissions systems such as diesel particulate filters (DPF) and catalytic converters.
3- Provide no proven benefit in terms of performance or cleaning.
Experts on diesel forums point out that ATF is not formulated to be burned as fuel and may contain metals and dissolved salts that can leave damaging deposits on pistons and injector nozzles over time.
What Are Safer Alternatives?
To maintain your fuel system in good condition, it's better to:
1- Use diesel-specific fuel additives approved by manufacturers.
2- Perform regular maintenance as recommended by your vehicle's manual.Avoid unsupported or risky DIY fuel treatments.
Conclusion
While adding ATF to diesel might seem like a cheap and easy fix, the potential damage far outweighs any perceived benefits. It's always best to follow manufacturer guidelines and use products specifically designed for diesel engines.
#3 ·
Yeah, the ATF treatment is straight out of the Fifties and Sixties.
I think you’ll get some argument on the whiskey treatment though…
#5 · (Edited)
It’s not anecdotal. And it’s not really a small amount either. In 50+ gallon tanks I’d put in several quarts. 4, 5, 6, 8, + quarts - hard to say exact concentrations when there there are no fuel gauges in older heavy equipment - graders, blower, excavator, back hoes, etc etc.
This is an old technique that was employed on older machines. Ie, older heavy mechical Cummins, Perkins, detroits, etc etc etc. Employed by many, many operators, especially those running NATO, Jet A & B fuels, and these days modern diesel fuels in older engines. Specifically, for the fuel pumps. Even older diesel fuels before the low sulphur etc, people would run it for longer pump and injector life.
Most of the guys who can tell you the difference, such as the person I leaned this from long ago, are probably long dead. He ran a pump shop and could tell exactly what fuel and lubes you ran in your pumps just by opening it up and looking at it. The ATF is a lubricant.
None of this applies to any modern diesels with emissions and modern cp4 fuel pumps - I know nothing about them. And I’ve never heard a pump shop recommend that to any one with something new.
I can tell you from hard earned experience ruining pumps, running mechnical Cummins, case, Detroits, etc - it actually works. It solved tearing up pumps and pump shafts for me. It was not anecdotal. The only thing that was changed was the addition of ATF running NATO and Jet fuels. Nothing else.
Why ATF? Because it worked well, it was cheap, and widely available everywhere. By the case or drum. The only warning I give people if doing so in an older diesel engine pickups - it will tint your fuel red, the more atf, the more red. If you’re in an area that checks for dyed fuel, you might have a hard time talking your way out of it.
#10 ·
I agree with @Jeff-F350 - it's been around a while. I think it got somewhat of a resurgence when the US decided to reduce sulfur to 15ppm in 2006. Sulfur was the lubricant agent in the fuel. People were looking for ways to compensate for the lack of lubricity. ATF, 2-cycle oil, used motor oil were some of the things that circulated around. Yes, older engines could tolerate it, but no, it wasn't the best idea. The newer engines are so advanced from the old ones that running the above is bad for them.
#14 ·
I ran an aviation MRO (Heavy Maintenance - DHC6, DHC8, ATR, Hs748, etc) business, and operated an FBO / Airport for many yrs. I literally grew up on an airport and flying. Trucks were a big part of the operations and my side line / hobby.
Jet A and Jet A1 are the same fuel. ‘A1’ designates it has an anti ice/gel additive. While ‘gas’ turbines (PT6) are called ‘gas turbines’ and will run on gasolines, it is not recommend due to higher operating temperatures. On the PT6 engines, there are time limits to how much and how long gasolines can be used.
Jet A1 is not blended with gasoline.
I have experience with the PT6 line of engines, and have P&WC HM and LM, TM, factory training on them.
As my previous posts, I would not recommend Jet A to be run in equipment without a lubricity additive. That one is through hard leaned/earned knowledge.
