I started using Archoil products a few years ago. Found out about them by accident while looking for friction modifiers that could be used in lube oil for 4500hp, 12kv horizontal pumps. The reviews were many, always positive- and hard to believe, and they make an additive for the 6.0? I also own a 05 F350, 6.0 that I have spent my kids inheritance repairing.
I'm also a former drag racer from the 70's and 80's. We were always looking for that magic elixir. This included using the wife's spaghetti pot to heat up cans of STP so I could pour it into the hemi 4-speed on my 69 Roadrunner.
Well I gave it a try. Used it in my oil change. Started the truck and noticed an immediate change in the sound of the engine, quieter, idle smoothed out. After putting about 50 miles on it I noticed my slight stiction issue went away. I live in Nevada and work in San Diego, CA, truck always used 21 gal of fuel going home, (not towing my trailer). With the Archoil I used 18 gal. This is based on around 30 trips. I also use the AR6200 in the fuel tank- 15ml in 38 gal.
Anything that helps with friction and heat has to be a plus. I have since started using it in the fuel, engine, and stick shift for my 87 Turbo Coupe with a FI 302. Same results- motor idle smoothed out, noticed a difference in the 5 speed shifting.
Cost is nothing when you consider the benefits and how expensive repairs have become.
Hope this helps someone trying to decide what and if additives can help.
