Hello all.
I've had mixed experience with K&N Filters.
On past performance cars I've seen 1-3 hp gains from just the drop in K&N Filter when on a dyno swapping between runs on the same day with a stock clean filter.
I've also seen on some vehicles I've had that they did nothing. On my Hellcat, I actually saw a 2 hp drop on the average of several runs (with proper cool down in between) compared to the stock paper filter.
I do not want to substitute particulate filtration for slightly better breathing either.
But figure if it's time to change out the stock filter, and there is an aftermarket that works just as good in the filtering department but flows a bit better too, well then might as well go with it.
So what do you all recommend in your experience with the 6.7 PowerStroke.
Input on a CAI system would be appreciated too, is it worth it on these trucks?
