21 - 40 of 41 Posts
Can you post a link or directions on what you did in Forscan to enable the auto lamps and DRL?
I'm going to be tied up for the next couple of days. I'll try to post up some screen shots of what I did to make it happen.
It was pretty simple. Just got into the BCM and turned on the features I wanted. I didn't change any of the (as built) files.
I did it tonight. Did you also change them in the last module? (IC something module).
So does anyone know if there's an OEM way of adding autolamps and fog lights to an XL? I have a 2012 F-350 XL, but has power windows/locks/mirrors? I've been searching the forum/ebay/google and can't find any info on adding it to an XL model, just XLT. I'm guessing that likely means it can't be easily done.
-Cody
-Cody
if you have an XL with power windows/locks/etc you can buy the same kit for the XLT, Lariat, etc.
XL trucks with manual windows/locks/etc need a module for the fuse block in addition to the kit the xlt/lariat/etc uses.
Do you know anything about the reprogramming I've heard mentioned? How would I explain that to the dealer? Is there anyway I can reasonably purchase the equipment to do it myself? I loathe the dealer, but I can't justify spending several thousand dollars either, haha.
Thanks for the reply!
-Cody
You should be able to use FORScan to do the programming.
-Cody
The only thing needed to program is if you get the auto headlights. I used forscan.
-Cody
There's no programming, it's all just physical equipment, just like if you were to add an aftermarket light bar. The only time you'd need programming is if you wanted to add the auto-on/off stuff (lights come on automatically when it's dark).
Look behind your front bumper, there should be a couple wire harnesses with caps on them. Those are for the fogs. You just mount the lights, plug them in to those harnesses, and swap out your headlight knob for the one with the "pull for fog lights" option and you're done.
Sent from my SM-G920V using Tapatalk
Cody,
You might need the sensor to turn on/off the lights if you try to add auto lamps. The sensor usually sits on dash in the center. Not sure the wiring for it will be there. Also, not sure the trucks use the same SCCM.
Reactions: exalted512
Cody,
Thanks Larry! I'm very acclimated with electronics, so I know I can figure out a way one way or another, but I am trying to keep it appearing as stock as possible. I was hoping to find a direct answer before I get started so I don't buy things that I wouldn't use (and waste money), but the autolamp feature is something I've had since 2004 and I don't necessarily want to revert back, haha. I have an 04 elantra with a manual transmission that has autolamps...
It might be a bit, but once I have something figured out, I'll start a thread describing the process for those of us with XL's. I emailed several different vendors on ebay with mixed responses. Some say they've heard customers reporting back that it works, others say there's no way. I'm actually surprised I can't find anything more concrete, but I sincerely appreciate all the help on here.
-Cody
Thanks. The auto headlights is really what I'm after, the fog lights are just a bonus. I was just curious because the headlight switch pictured doesn't appear to have an "auto setting", just the normal off/parking lights/on.
-Cody
I did just the auto lamps. You need the sensor and the headlight switch. You can use forscan to enable the feature or the dealer can do it.
But is yours the XL or XLT? Mine is an XL which is why I haven't been able to get a 'for sure' answer yet.
Mines an XLT but I gave you your for sure answer already. :wink:
If you have power windows and such you are good with the XLT kit.
My truck is a 2015 XL with all power.
I bought the XLT kit (without a new BCM).
I did use Forscan to get the autolamp to work because they lights were on ALL the time with the switch in Auto position.
Do you have a link to the kit you bought? I didn't know they made XL's with the chrome grill!
Here ya go
So I ended up buying the above kit (FOG LIGHTS, XLT - FORD (BC3Z-15200-BA)) and it worked great on my 2012 F-350 XL (with power locks/windows)! Thanks everyone!
Couple things that I learned doing it (for future searchers):
1. I forgot that someone above mentioned to remove the bracket immediately behind the fog light housing. Stupid me didn't really look at it and realize it's 4 easy bolts and it will make installing the fog lights much easier. Everything is pre-wired, so just follow the instructions and plug them into the existing plug on the truck.
2. There is a "blank" in the dash for the light sensor, complete with wiring. Pull the blank, plug in the new sensor and snap it into place. Pull the old light switch and the new one plugs right in it's place.
3. Also as mentioned, the fog lights don't come on unless it's running.
4. The headlights will stay on in auto all the time until it's programmed with Forscan.
That's it! But since I had zero knowledge of Forscan, there might be other people with a similar lack of knowledge, so here's the basics. After I paid $5 for the app, I found out it doesn't work for this.:
**As a disclaimer, by using Forscan, you are changing stuff in the computer in your truck and have the potential to really screw stuff up. There's no way I'd change anything in there if you're not comfortable and at a minimum, do the initial back up so if you do screw it up, you can revert back.
1. Get yourself an OBD2 adapter (I used a wifi one, but they also make cable and bluetooth)
2. Download and install FORScan. Just google it. My post count is too low to post links :(
3. Register on the FORScan forums and wait for your account to get activated
4. Once activated, request an FORScan extended license from the same page where you downloaded it
5. Copy the extended license key into FORScan and make sure it then indicates "Extended" (more info on how to do that here on the forscan forum itself
6. From there, you need to connect your computer to the OBD 2 adapter, open Forscan, hit connect to adapter at the bottom left, then let it run its diagnostics.
7. Click on the Configuration and Programming, then I believe it was under BdyCM and hit play. I enabled the ambient sensor and autolamps if I recall correctly. Do not click the one that says "As Built". The other one is pre-programmed with easy to read and understand options. Check what you want and hit write.
8. Hit stop when you want to switch between control modules, then hit disconnect before you turn off Forscan.
There might be some things here and there I forgot, but that's the gist of it. I found it to be very easy. If you're good at following instructions, there's some other options that you can change in Forscan. I enabled a feature to allow fog lights and high beams to run at the same time ("bambi mode") and lengthened the "auto blinker" (when you hit the blinker but don't fully engage it) from 3 blinks to 5 blinks. Those instructions can be found at ford-trucks dot com and search for forscan-and-as-built-data
Thanks again everyone!
-Cody
I am attempting the same project with the fog lights. I have a 2012 f250 XL I bought a new switch that has the fog light feature. But I'm still not getting power to the plug by the bumper. As far as I know I have all the fuses and relays, is there something I'm missing?
21 - 40 of 41 Posts
