Has any experienced the air conditioning only blowing through the defrost vents? It blows cold but something with the panel must not be working correctly. Thoughts?
to my limited knowledge the is the ac and it sounds like something in there is leaking perhaps the vent is leaking that would surely account for warm air intrusion into your ac increasing at speed as more air is blown about under the hood :dunno:My AC is doing the same thing. When I turn the ignition you can hear the vacuum pump running and never stops. I can feel air coming out of this area - not familiar with what it is. Is that the heater box? If so is there a vacuum sensor just inside of that box that might be bad?
did your truck leak more condensation prior to this? sounds like a similar issue on mine....AC blows colder at slower speeds and when cruising on freeway its not cold...not trying to hyjack the thread just tryin to figure out my issue.
thanks
