Someone out there please point me to the correct place to post this if this isn't it. Don't want to be "that guy"...
So, I've had my 95 for a few months, about a month and a half ago I rebuilt the fuel bowl because it was leaking like a sieve. New orings, hoses etc, and I unclogged the FPR screen. There was solid build up about the thickness of a nickel on the screen. Put everything back together, ran so good.
While I had it out I cleaned what I could reach and noticed the fuel pump looked pretty darn new.
Last week, fired right up, drove where I was going and noticed blue smoke. Loaded up what I was getting, fired right up, made it most of the way home (blue smoke) then I was going 60, then 55, then flooring it going 45. Coasted off the interstate and it hasn't fired up since.
A mobile mechanic came out and thinks it's a bad fuel pump since it seems like it's just getting starved for fuel. Everything else checks out except fuel pressure. We had it running after it sat for awhile then it died.
my long winded question is: Does it make sense that previous owner replaced a failed fuel pump because the FPR was clogged (both filters were filthy) so the pump was failing prematurely. And now that the flow through the fuel bowl is more correct, the "new" pump has already been worn out from before cleaning and can't keep up so it's stalling out the motor?
I'm still learning how diesels work, so any help or suggestions would be awesome.
