I'm having the same issue and actually been struggling with this for about 5 months. When I first start it the engine runs perfect. Once it gets up to operating temps it idled choppy, lopes and misses at low rpms
(1200-1500rpms). I have the A/e software so ran all the tests it failed a three of the injectors so I put all new Hybrid injectors in and still had the same issue.
I spent the last month checking compression, fuel pressure, wiring harness, UVCH, changed ICP & IPR,CPS, Ran buzz test. etc.... All passed. So I finally started to believe the CCT test I ran that told me that #6 & #8 failed the test for contribution/balance fault. The PERDELS on 6 & 8 were running 4% to 7%. Number 8 is a common problem that shows up with a CCT test and is not always correct. So I swapped the #6 injector with the # 4 injector to do a quantitative test and low and behold number 4 came up bad and number 6 & 8 were fine. The PERDELS on 6 & 8 went to o% and the PERDELS on #4 went to 5%. So I just sent that one injector back to be looked at even though I just put it in 1 1/2 months ago.
The injector Co. says sometimes they flow fine on the bench and just won't fire correctly in the truck. Something about internal leakby. I'll know some more next week and I'll post it up. Look at my post in this forum "I think my IPR is Bad" for the whole story.
I've had it to several dealers and supposed diesel shops who all seem to be parts replacers.
They all say the same thing. 7.3L tend to idle rough. This is a bunch of bull. My truck idled smooth as a baby's butt without the smallest hiccup for a 125,000 miles.
Good Luck:dunno:
