6.0 Crank no start (but wants to) with codes.
17K views 27 replies 6 participants last post by  Hydro
2005 F250, 6.0L, 250k miles.
Driving in town today, truck started running rough at idle right near my stop. I immediately thought it was a bad injector as I have had that happen before and the rough idle, slow get-up reminded me of that. Made it there and went in for a few minutes. Came out and truck started up but still running rough. I only made it a couple hundred yards before it died and I coasted into the supermarket parking lot. It cranks but wont start, but it does sputter like it is getting fuel. Checked the Torque app and pulled the codes in the picture.
ICP reads 0 with KOEO, reads well over 500 when cranking.
FICM sync reads 0.0 with KOEO, reads 1.0 when cranking. Voltage is up as well.
IRP is 14.7 with KOEO, reads 50ish% when cranking.
I had the FICM re-soldered about 2 years ago.
Any ideas? Could it really be the crankshaft sensor? I thought the failure on those is pretty rare. Also, doesn't the crankshaft position sensor cause the cam sensor fault. No way they both went out at the same time.
Don't worry about the P2269. I've had that for years and have yet to clean out the housing.
#2 ·
Do you have Sync (not FICM sync)? What is your ICPv KOEO and while cranking? I'd want to know fuel pressure too to rule that out. Also need FICM Lpower and fuel pulse width.
-jokester
#4 ·
Sensor voltage will tell you if the system is really making oil pressure -- good to check that before believing the pressure readings
Are those active codes? -- clear the codes, only need current
Your description suggests a fuel problem
Do the injectors click when you first key on?
Do you hear the fuel pump running? Does is sound strong and even? (no bubbles)
How much fuel in the tank?
Filter condition is?
Reactions: bismic
#7 ·
More info:
ICP voltage KOEO 0.2, 1.4 when cranking
FICM Logic Power KOEO 12.0, 9.5 when cranking
Fuel pulse width KOEO 0.0, 1600-1700 when cranking.
To answer Hydro's questions:
Do the injectors click when you first key on? YES
Do you hear the fuel pump running? Does is sound strong and even? (no bubbles). DON"T KNOW, WILL HAVE TO CHECK. NOT SURE WHERE TO LISTEN TO BE HONEST. ON TOP THE ENGINE?
How much fuel in the tank? 1/4 TANK
Filter condition is? I WOULD ASSUME SATISFACTORY - DUE TO BE CHANGED AT NEXT OIL CHANGE WHICH IS COMING UP.
CODES: I cleared the codes and the Crankshaft (P0336), Camshaft (P0341) and Water in Fuel (P2269) did not reappear (yet).
bismic - I agree on the glow plugs. I did not realize I have so many out until I pulled the codes.
#8 · (Edited)
As far as glow plugs go, the engine SHOULD start on a warm day if the only issue is glow plugs. Trouble is, it takes more cranking and if you are low on cranking rpms (weak starter), or have some reduced compression, or the high pressure oil pressure is marginal, it can really make it hard to start.
Unfortunately we don't always get a CEL with glow plug problems.
Edit -
The fuel pulse width and ICP volts look good.
9.5 volts for logic power when cranking is too low, but it SHOULD start with that.
Make sure your batteries stay charged up and that cranking rpms are 150+ for better chance at starting.
#10 ·
The 1/4 tank may cause the problem if the pickup foot is gone -- mine is for sure -- putting in a bottom sump when I get time
The fuel pump in in the HFCM -- under the drivers door -- you have 20 seconds at key on to listen
With the symptoms you described -- I would bet the fuel pressure is low
plugged filters or the pickup foot at 1/4 tank
#11 ·
Ok then. I will listen to the fuel pump and see how long it takes to fill the empty fuel bowl. THEN, I will fill it up with fuel and attempt to start. I will report back my findings.
I did have the fuel pick-up replaced years ago. I could hear something banging around every time i went over a big bump but there was nothing in the bed of the truck! Anyway, a shop repaired it for me, but ever since it seems like I went from a usable 28-29 gallon tank to a usable 24-25 gallon tank.
#13 ·
UPDATE:
Didn't get home until pretty late last night :(. I still managed to try and listen for the fuel pump. Honestly, I don't hear anything really. I hear the injectors clatter and about every 2nd or 3rd turn of the key I hear something run for about 15-20 seconds. But its not coming from under the drivers door, near the fuel filter housing. Is the fuel pump & filter housing all the same unit?
I was alone so I was not able to check how fast the fuel bowl filled.
In any event, I did haul fuel cans to the station and put 20 gallons of diesel in the tank. I cycled the key a few times and tried to start the truck but it didn't. I cranked it maybe 10 times, 5-10 seconds each. At first it just cranked, no sputter. The more I cranked it the more it sounded like it wanted to start, like is was finally getting fuel (just barely sputtering really). I could hear the starter revs going down so I just stopped for the night as I was whipped.
I should add that the batteries have been on a charger this whole time so when I do crank, the revs are up there.
At this point I'm still on board with the out of fuel theory. Perhaps I have too much air introduced in to the system or the fuel pump is out. How can I remove or cycle things to remove any air in the system? I think i will pull the second filter and fill the bowl to confirm the pump is even pumping. If pumping, re-install the filter and cycle the key several times then try and start it.
EDIT: I pulled the codes again and the crankshaft & camshaft sensor codes have not re-appeared.
#14 ·
Yes the pump is in the filter housing under the truck -- should be pretty easy to hear it running
turn the key and shut the door (roll the window down, so the next thing on here is not "I locked myself out") -- stick your head under -- got 20 seconds to listen
You can look thru the crack at the rear of the hood and see the fuel filter, kind of -- and still reach the key
the upper filter should fill pretty quick, 2-4 seconds
you can leave the key on the whole 20 seconds if you dont mind making a mess
If the pump is any good, the air will be pushed out in the first couple of key cycles
Reactions: bismic
#16 ·
Yes -- then runs continuously after the engine starts
#20 ·
The vacuum pump should only run till the pressure is good, then turn off -- you could disconnect the harness so it does not run for the time
The black plastic, opposite the filter cap is the pump motor, you should be able to feel the motor running
Both '06 trucks I have had could hear the pump from the driver seat with the door closed -- after the dinger stopped and the injectors got done
#21 ·
UPDATE: Fuel pump problem.
What I was hearing before was for sure the vacuum pump, so I unplugged it. Cycled the key several times and only heard the injector clatter, never heard the fuel pump. I removed the secondary fuel filter. There was probably 1/2" of fuel in the bowl. I turned the key on and went around to get under the hood and the fuel level in the bowl didn't move. Next, I went under the truck and jiggled the 3 connectors at the fuel pump housing and cycled the key again and got nothing. SO, I assume a bad fuel pump.
On a side note: I did notice however, when I pushed the lower right connector (which I believe is the water in fuel sensor) fuel would nearly stream out of the connector.
Any reason not to stick with a motorcraft fuel pump? Any special tools needed to perform the swap?
#22 · (Edited)
Sources for the pump by itself:
At dieselfiltersonline.com, you can get free shipping for $250, so buy enough filters to get to $250 and you can save some bucks.
That said, the HFCM contains some components that wear out so it might be worth your while to just buy a new HFCM. Sounds like you at least need a WIF sensor (in addition to the pump), and maybe a pigtail.
#25 ·
Thanks for the links. I think I will just swap the entire HFCM as I have owned the truck since 50K miles and never changed the HFCM out, or serviced it for that matter. Besides, I can get one today and get the truck back on the road.
You mention pigtail. Do you have a link for the pigtail or are you suggesting to just replace the connector (cut wires & solder) at the WIF sensor?
#23 ·
So, now onto why the vacuum pump is running -- it should only run for like 30 seconds and turn off -- then only come back on if you mess with the heater controls
#27 ·
PROBLEM SOLVED:
A new HFCM solved my problem. Installation was not too bad either. I have 4WD so the drive shaft was in the way a bit. However, I left the drive shaft in place and managed just fine. I also changed the wire harness while I was at it. Once installed, I pulled the secondary filter to evacuate as much air as I could, then re-installed. After several cranks it started and now runs just fine.
I did notice that the HFCM (and harness) I removed had a third plug on it. The replacement only had two plugs on it. Working fine so far. An added bonus is I no longer get the WIF warning!
A big thanks to everyone who helped guide me!!! I'm always appreciative of the knowledge on this site and I try and contribute when I'm able.
Ryan
#28 ·
Glad you got the truck fixed -- that "extra" plug is a fuel heater, no longer used
Reactions: jokester00
