Alright guys so I ordered the blue spring kit from sinister diesel and decided to add it to my 2004 6.0 powerstroke. I’ve only done an egr delete and catalytic/muffler delete(straight pipe). I installed, re-installed and did every trick in the book even as far as keep the plastic O ring on the plunger holder(not sure what that part is called. Today I re-installed the OEM regulator and OEM spring and I STILL can not get this thing to run right. It has a lope and is certainly not running right. I know the air flow and exhaust sound that my 6.0 is supposed to have and I can tell I am having some kind of a fuel issue but I can not figure out what the issue is coming from. I can’t find an air leak in any fuel passage or line. Also to note, there was nothing wrong with my truck before I decided to run this upgrade and I haven’t driven since the first time I installed the spring kit and noticed something wasn’t right. I’ve only listened to it idle. I just read a lot about how it improves the health of my injectors. I’ve also read where that can only be true in some cases. Is there anyone that might be able to help with this issue?
