285/75 on 16x10 wheels
1 reading
13K views 7 replies 5 participants last post by  Discount Tire
I have 285/75r16 pathfinder A/T and they were put on a 16x10 raceline wheel. My question is, will I be able to tow a camper without any issues? Thanks
768722
768724
#7 ·
if the tire is rated ( it is as you stated and I checked also ) then you should not have any issues related to rim size , tire seat, and wear
you also need to check load ratings vs weight ( I am sure you have .. i think it was a 124 so 3527
many people go much larger rim than is rated and many times the MFG has just not done the testing for the larger rims ( according to Toyo )
#8 ·
Thank you for your business,
We wanted to confirm, the 285/75R16 would be safe for your application and you can tow with it. As long as you are between the tire manufacturers recommended wheel widths,(7"-10" for your tire size) it is a safe application, and will carry the tires rated capacity.
