2012 6.7 NOX sensor
1.1K views 11 replies 4 participants last post by  maverick62
So my NOX bank 1 sensor failed . it is the needle type probe. When i look on Amazon they look like a O2 sensor for a car (round short probe) The one i found with the thin needle said: EGT exhaust gas temp sensor?? all 4 of my NOX sensors are the needle type 2" long ..What gives?
#9 ·
For the life long love of piss.2012 6.7L I cannot see and find the #1 NOX sensor. So starting from the rear i have the #2 NOX and the EGT sensor side by side, then working towards the engine 3 more EGT sensors the injection port for diesel and def fluid and following the exhaust pipe all the way up vertical no NOX ? WTF
#11 ·
If this is truly a 2012 truck there is only one NOx sensor and module located at the rear of the catalyst assembly.
