I'd like to upgrade my stock headlights to something brighter. What do you recommend? Thanks in advance for your time!
Thanks very much! Can you send me a link to something you recommend?I'm partial to hid lamps in 8k color (slight blue tint). By far the best type of headlight I've used (in conversions) yet.
Perfect, thank you for the link!These are what I put in my '06 Lariat -- it had some cheap LED in there and the output was all wonky
the Morimoto 2 Srtoke V3 works well with the stock housings
possibly will look into projectors in the future, but for now the LED is working great
H13: Morimoto 2Stroke 3.0 | Headlight Revolution LED1524
Morimoto's bright H13 2Stroke 2.0 LED bulbs provide you with the increased output you need at night. Headlight Revolution is your source!www.headlightrevolution.com
What orientation did you clock them for best results? I'm about to ditch my projector retrofits and go with 2strokes. Yes, I know it's an old threadI did have to "clock" the bulbs as they were turned a little from vertical and throw a much better pattern now
